Thread: SWG for an in-ground tub
    We are nearing completion of an in-ground spa (no pool) and are being asked by our pool builder if we would like a salt system.
    Is an SWG necessary or useful for a spa or is it overkill?
    27,000 gal liner pool. Hayward S360SX 36" sand filter, Dolphin Dynamic robot cleaner, Dolphin Supreme M4 pool cleaner, Aquatemp FT40Kst 3 phase Heatpump, Pentair IntelliFlo VF 3.2KW pump, Aquamatic Hydromatic safety pool cover, Autopilot Pool Pilot Digital SC-60 salt water generator. 2 Inch piping throughout.
    Jul 2007
    Brisbane, Australia
    874
    Re: SWG for an in-ground tub
    it depends
    it's more convenient to use SWG, but will probably be cheaper to just add bleach manually
    22,553
    I agree with Strannik, it's probably going to be cheaper to sanitize with bleach. With a stand alone spa you're going to be dumping the water periodically so you'll be wasting the salt fill and having to re-add it every fill.
    I'm sure someone will correct me if I've made an incorrect assumption.
    30,432
    Certainly not a correction, (I think bleach will always be cheaper) but I saw a product at the Orlando Pool Show that intrigued me. It was a SWG that was made for spas. Pretty close to brand new, I think.
    It simply plugged into a 110v source (thru a transformer that reduced to 12v) and then was draped over the edge of the spa into the water and it began generating chlorine. It was around $250-275.
    It had no moving parts (you "tapped" it to change percentage output) so it was well sealed. If you removed it from the spa, it shut off.
    The only thing I questioned was by simply draping it over the wall, I wasn't sure if the concentrated chlorine production that close to the fiberglass wall would have any negative effect.
    Aug 2007
    near the swamp
    806
    Nexa Spa made by American SPS who make the Resilience Salt Systems, I reccomend they hang it in front of the spa's skimmer.
    Thanks for the information, everyone. I'll discuss it with the builder.
