Results 1 to 7 of 7
Thread: What is the best valve..
    Apr 2008
    Edison, NJ
    6
    I want to replace the 2 valves on our above ground pool, the ones that came with the pool are not good, one lost the handle on the fist year and I now use pliers to open and close it.I want to stay away from the pvc valves. Can I use an industrial ball valve. or what does anyone recommend?
    NJMarine
    Cheryl
    14X42 Intex Ultra Frame
    22,548
    Re: What is the best valve..
    Sure you can use industrial ball valves. If cost is no object.
    I'd go with all stainless steel if I were you. You might consider using PVC but instead of the cheap ones, get true union type valves. They're made for industrial service and you can replace individual parts if ever needed.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Bama, you got a pic? my valves were giving me a hard time last year and I'm thinking of replacing them upon opening this year.
    22,548
    Take a look here True Union Ball Valves. They're pretty expensive but not nearly as much as an all SS valve would be.
    Apr 2008
    Edison, NJ
    6
    yea , I know ss valves are very expensive. Thanks for the tip I'll check out the true union valves. I was thinking SS but since I posted I found out my daughter, who's pool this is, just got laid off, so Dad my have to help out and money is more of a consideration than it was hours ago. Thanks for the tip, I really appreciate it , Semper Fi to all the Marines out there.
    Cheryl
    South Central NJ
    3,192
    Jandy NeverLube gate valves. Reliable and servicable(though unlikely ever need to). They come in 2 way (in/out) and 3 ways (Shaped like a T). Available in 1-1/2. 2, and 2-1/2" sizes. They are Socketed and glued on.
    Scott
    Owner of - PoolGuyNJ LLC
    Apr 2008
    Edison, NJ
    6
    Thanks again I'll check out the Jandy as well.
    Cheryl
