Results 1 to 15 of 15
Thread: Stupid question? What to do with samples after testing?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I am a first time pool owner, and sooo glad I found this site!
    I am waiting for my K-2006 kit to arrive. In the meantime I tried out the cheapie test kit that came with the house, and I was surprised to see that the chlorine test maxed out at 3ppm, which is basically useless based on what I have read here.
    Playing with that cheap kit did lead me to a (stupid?) question though...what do you do with your test sample after you are done? I assume it shouldn't go back in the pool with all the titrate, reagent, etc in there? Should I just throw it down the drain? Do a shot?
    Thanks...probably the first qusetion of many!
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Stupid question? What to do with samples after testing?
    I usually wash mine down the drain. I guess you could dump it in the yard if you test outside.
    Love TFP? Become a
    TFP Supporter!
    Feb 2008
    Denton, TX
    5,061
    I usually just pitch it in the grass. The grass doesn't seem to care. As far as putting it back in the pool, I have heard that this is a no-no for CPOs but that the chemicals are pretty weak and that you probably wouldn't have any untoward experiences by doing so.
    My vote is yard or drain. Shot? Hmmm...I'd have to pass.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by svenpup
    Welcome to the forum...
    If the "cheapie" test kit features an OTO (yellow) chlorine test, it's not entirely useless... especially if you have some idea of your current stabilizer level (aka CYA or conditioner). If the CYA level is 50 ppm, for example, a 3 ppm Free Chlorine reading is adequate (especially for pools where chorination is effected by a Salt Water Chlorine Generator). The big assumption of course is that the Total Chlorine level measured by the OTO test is equal to Free Chlorine as measured by FAS-DPD (found in the K-2006 kit). Soon you will be able to extinquish any doubt about the truth of that assumption.
    ... nice avatar, BTW.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Dec 2009
    Central Massachusetts
    2,690
    I dump mine in the mulch bed
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,090
    Is there anything wrong with putting it back in the pool
    I have been doing that
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Dec 2009
    2,690
    Quote Originally Posted by Brentr
    Not that i can see. I've done that. Couple mLs in 14,000 gallons. No big deal.
    Feb 2010
    12
    If you are just doing a very simple 'at home kit' using OTO and Phenol for CL and pH readings, there is nothing wrong with putting the sample back in the water. In fact, Phenol is commonly used for leak detection in pools. Hope that helps =]
    Manager of retail pool location in Ohio
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by knick_mike
    Yes, it's unlikely that the ingredients used in the minute quantities requisite for residential testing would cause any water quality issues -- melanine, thiosulfate etc. -- though Taylor advises against it. I initially thought everyone dumped the test results and excess titrants back in the pool because my PB's service did it that way... but pool owners don't have to test pool side, a realization that came to me during the first year of pool ownership on a cold December morning in pouring rain...
    Water dilution and rinsing down the sink into the sewer/septic system works. The chemists who read this will post if this undereducated presumption doesn't hold water.
    __
    One of the chemicals used in the OTO test is a suspected carcinogen. The quantities used in testing are tiny, but I still wouldn't want that in my pool.
    Dec 2009
    2,690
    Which one in the OTO test?
    The OTO test measures the total chlorine level, drops added to a sample turns the water various shades of yellow which is then compared to a color standard.
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by bk406
    Orthotolidine reagent. Taylor labels it R-0600 - it's typically used in lower end residential OTO kits for testing chlorine ppm. (The phosphates, acids and sulfates used in the DPD kit chlorine tests aren't identified as potential cancer-causing agents in the documentation provided by Taylor.)
    Orthotolidine dihydro-chloride 612-82-8 <0.5 ppm Suspect carcinogen
    The product instructions are explicit about the inadvisability of dumping it back into the pool:
    http://www.taylortechnologies.com/produ ... umber=5314
    __
    Dec 2009
    2,690
    I was asking what chemical in the test is a suspected carcinogen.
    Orthotolidine. The carcinogenic activity is not fully confirmed. It is listed as a possible carcinogen by IARC and NTP, but not listed as a carcinogen or suspected carcinogen by OSHA.
