Thread: Aqua Logic clock is fast
    We have an Aqua Logic AQL-P-4 Control. The clock is fast. Now 15 mins from reset from DST. Yeah, I know, 15 mins in 4 mos. aint nuthin' to cry about. Just would like to know if this is normal or a potential problem. Thanks! (I have set the time with the remote control in the house.)
    16K gallon, Pebble tec, beach entry. Two 1 hp Pentair Whisperflos. One for Paramount MDX2 main drain, Paramount debris canister, and Pentair CCP 520 filter. One for skimmer w/sock and Paramount PCC2000 in floor cleaner. 3/4 hp Pentair Pinnacle for waterfall. Fiberstars fiber optic pool lighting. Aqua-Logic AQL-P-4 control panel with wired remote in the house. SWCG system that is not used. Ultra-Pure Ozonator that is not used.
    Re: Aqua Logic clock is fast
    Having some clock drift is normal and nothing to worry about. 15 minutes in 4 months is a bit more than average, but it isn't unusual.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Mine drifts too so I am reseting it at least once a month.
    Mark
    Thanks for the quick responses! I figured it was normal. Just don't expect a computer controlled system to drift that much.
    South Central NJ
    3,192
    It the temp changes that cause it.
    FWIW, Easy-Touch has a setting in the Schedule section that allows the clock drift, if predictable, to reset a predetermined amount of seconds once a month.
    Scott
    Owner of - PoolGuyNJ LLC
