Thread: CLarifiers/Sequestering Agents
    tjt040774's Avatar
    Apr 2009
    My water looks crystal clear; however, I have read on the Pebble Tec website that they recommend Jack's Magic Purple Stuff. Is this necessary? What are the pros/cons of adding this stuff? Just curious....
    Approx 18,000 gallons, Jandy CL 580 Cartridge, Gunite, 2 1/2 hp 2 speed Jandy, Aquapure 1400, Polaris 280 w/booster, LXi Jandy Heater, Jandy PDA 6, PebbleTec: Tahoe Blue, Depth: 3 1/2' to 6', Perimeter: Approximately 95', Spa: 10' x 7'
    Mar 2007
    San Rafael, CA USA
    Re: CLarifiers/Sequestering Agents
    Clarifiers and flocculants are not normally needed if you maintain an appropriate Free Chlorine (FC) level relative to Cyanuric Acid (CYA) level. Sequestering agents are not normally needed unless you have metal ions in your pool water. Generally speaking, you don't want to add unnecessary chemicals to your pool unless you really need them for a specific purpose.
