Thread: Question on purchasing Used Heater.
    How much would you offer for a Used Sta Rite SR333NA, They claim it has never been used. They are asking $900.00 and I am sure it has no warranty. What things should I check when I look at it? What questions would you ask?
    11K gal, in-ground 15'x33' San Juan Fiberglass, Pentair Whisperflo 3/4 hp pump, Pentair Clean & Clear Plus Filter CCP320, Pentair Inteliclor 40 SWG,
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Re: Question on purchasing Used Heater.
    Never been used eh?
    Gas: Look for pipe dope in the threads of the inlet to the gas valve (this could be evidence of prior hook up). Actually, if it's brand new, there is a plastic pug stuck in the valve at EOL/ assembly.
    Electrical: Look at the wires that you hook the unit up to high voltage. If brand new, the wires will stick out of the j-box about 10 inches (You will need to bring a 5/16 and 1/4 inch nut drivers to get into the housing, and then junction box on the heater). You will be able to tell if it has been hooked up to power (wire strands will be wiggly and not straight).
    Water: The water connections are union-ed 2" and should be ready to accept pipe, not have a piece of pipe already glued in then the pipe cut off.
    And general cleanliness.
    For 900.00 i wouldn't buy it if it had water running through it. Even if it wasn't ever fired. There is no way of knowing what the water chemistry was. If it had water that was for instance say low Ph, copper would have been eroded away, reducing the life of the exchanger (worst case of course).
    Good luck
    Factory Warranty Station for:
    So now they say it is 3 years old and used on and off. How much now?
    Carla
    How about free? It is nearly impossible to determine the condition of the heat exchanger, which can be significantly damaged by just a few weeks of low PH. Unless it has a titanium heat exchanger, there is no way of knowing how long it will last, and thus it's value is quite low.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Quote Originally Posted by Carla_IL
    Carla
    That is tough! Maybe i would start out with: "why are you selling it?" (not that they would tell you if there was something wrong with it). They lied to you once already saying that it was never used and then changed it to "used on and off for three years". Not good. I'm afraid my advice is to pass on this "deal".
