Results 1 to 7 of 7
Thread: If it's not one thing with a pool it's another
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    There was a post a few days ago about using DE in a sand filter. I have tried that in the past, but the pool was so cloudy I had to backwash about twice a day and it didn't seem to do much good because the flow would drop to almost nothing before backwashing so I quit. After reading the thread and seeing where people claimed a big improvement I thought I would try again. My pool water has been clear as glass for months, but I thought maybe the DE would improve the appearance even more.
    The day before yesterday I added 2-1/2 cups of DE to get a 1 lb pressure increase across the filter. I turned off the pump timer and let it run around the clock. Yesterday the water was clear, but I could not tell any real difference. The filter pressure had not increased at all - so-far-so good. The pump ran all day and all night and today the pool still looked about the same as always and the filter pressure was still where it was when I started.
    This afternoon I decided to skim some leaves off the surface and was walking around the pool and came to the shallow end directly across from one of the returns and when I looked down the bottom was a nice pure white - WHAT IS THAT? My first thought was the liner had been bleached out, but I got out the pool brush and brushed the bottom and a nice pure white cloud came up. OH **** - it looks like some of the DE got though the filter and settled out on the bottom. I started brushing in a few more places and everywhere I brushed a white cloud appeared - no wonder the pressure had not increased all the DE went though the filter into the pool.
    I'm reasoning the only way that could happen is if some of the inlet water is short circuiting the filter and going straight to the outlet. That must mean the multi-port valve gasket is bad and I just happen to have a spare. I've learned that the gasket should be replaced and the spring and stem assembly lubed up about once a year. So I remove the top of the valve and start to scrape the old gasket out, but think to myself I better wait and make sure I can find the spare first. Well I find the spare, but guess what - it's the wrong gasket and will not fit my valve. So I'll have to make another trip to the pool store tomorrow and listen to everything I'm doing wrong in caring for the pool from a 19 year old high school drop out. I hate going in that place. I don't want to be rude, but it's all I can do to keep my mouth shut.
    Now I'm going to have a heck of a time getting all the DE out. Guess all I can do is vacuum the entire pool and hope it stays in the filter this time.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    South Central NJ
    3,192
    Re: If it's not one thhing with a pool it's another
    While you are removing the MPV, note to yourself how much friction exists as you lift off the MPV. If it isn't tight, it's possible DE shot in the return pipe. A slight crack in the pipe is another possible cause. It might be visible if, after pulling the MPV, use a shop vac in wet mode to draw the water out of the tank from the up pipe. Happens sometimes with Haywards.
    Scott
    Owner of - PoolGuyNJ LLC
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Another thought: Have you looked at the sand bed? If it is channeled that might facilitate the "leaking" of DE powder.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: If it's not one thing with a pool it's another
    Also, does your internal air bleed (tank bleed) still have it's screen?
    Factory Warranty Station for:
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Quote Originally Posted by Pool Clown
    I don't believe this filter has an air bleed. It's a hayward model 244T, but it's an older model (1991) and does not even have a bottom drain.
    P.S. I didn't pull the valve body just the top, but guess I should. I haven't looked at the sand bed in two or three years. I'll also inspect the inlet pipe for damage.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Looks like your bleed is integrated into the top. I believe you are on the right track though. Channeling, a bad valve, or gasket.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I found the problem it was not the gasket it was the O-rings on the valve stem. They were hard and grit bound them up so that the valve was not closing down all the way. The inlet pipe looked good and there was no evidence of channeling. However, the top of the sand was almost completely covered with dead ants. There were hundreds if not thousands of them. Guess they are not being back washed out. I removed the ants, added 50 lbs of sand, buttoned every thing up, and it is now in service - and hopefully working like it should.
