Results 1 to 8 of 8
Thread: Pattern removal on liner
    30,419
    Hi, folks,
    Visiting my father-in-law in FL. Hope you can see from the photos the pattern from his 3 yo liner is gone in spots....especially where walls and floor meet.
    Water test results are:
    pH - 7.3
    TA - 90
    FC - 4.5
    TC - 4.5
    CH - 230
    CYA - 30
    He is using a Barracuda G3 suction side Cleaner and that appears to be the most likely culprit but I am looking for any other possibilities. Anyone else see this happen with a suction side cleaner?
    Toms River, NJ
    151
    Re: Pattern removal on liner
    The only time I've seen that happen is when using granular chlorine (dichlor) or powdered superchlorinator - is this how he shocks his pool? If so, it's possible he doesn't brush up the granules that hit the floor and they have bleached the liner.
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
    30,419
    Yeah my first reaction was dichlor, too, but the very distinct color loss is 90% within 4-5" of the junction of the pool floor and walls. It's that very narrow white band right at the junction in the pics.
    It's hard to capture it in pics but it's pretty obvious that it seems to be a wear issue. You can see increased color loss at virtually every junction of any two surfaces. Even where the floor meets the walls on a 45 as it rises up from the hopper, there is this same pattern of color loss within a few inches of that junction of surfaces.
    If the G3 is not known for doing this (I can't imagine it is or it would be taken off the market) then they have purchased a liner with inferior color application.
    I suspect that to be the case because I can "feel" the color on the surface of this liner where other liners I have felt the color seems almost impregnated and you don't perceive the colored side with any difference in texture than the non-colored side.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I can't speak for the G3, but I do use a suction side cleaner, and don't have any problems like that whatsoever. I think you're on the right track about the liner if you can "feel" the pattern on the liner.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    I don't know anything about the cleaner described but I would suspect that the pool is being brushed with a bit too much vigor. The cove would be where I exert the most force on the pool brush extension to force it to level out at the pool bottom.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Feb 2008
    Denton, TX
    5,061
    I've got a G3 and I can attest that they do have a tendency to pattern, especially when the wearable parts (foot, diaphragm, fin disc, hose sections) get older and stiff or worn. That looks like wear from the cleaner patterning to me. Has anyone watched the Baracuda just to see where it tends to go when it's in the pool?
    I can't completely disregard chemical bleaching here though. If there exists a sort of "dead zone" around these areas where granules are pushed by water currents and allowed to remain undisturbed, this would then be possible. If this were a liner quality issue, I would think that you would see this sort of color loss all over the pool and not just on the bottom and edges.
    So...
    Primary most likely - Baracuda patterning
    Secondary most likely - chemicals sitting in dead space on the floor
    Tertiary most likely - liner quality problem
    30,419
    I don't suspect chemical issues because the "wear" is in such specific areas. They have had the same pool service since the liner was new and they have the water in perfect balance.
    Excess brush pressure is a good thought but this pool is rarely, if ever, brushed.
    The remainder of the bottom does show some slight wear but nothing like the areas where the vertical and horzontal surfaces come together.
    I am becoming more and more convinced that the liner pattern was printed on very poorly and, combined with the suction and friction effect of the G3, the pattern came off.
    Feb 2010
    12
    All suction side cleaners have the 'pattern tendency issue', it is one of the most annoying 'features' about suction-side cleaners. However, I have never seen a suction-side cleaner do any type of damage to the patterns on the liner. I hate to burst your bubble, but I would rule it out. On the other hand, you might check with the dealer he bought it from, on rare occasion some liner manufacturers have kind of...a recall, on a batch of liners. Liners can vary from dye lot to dye lot, and if the liner isn't actually taking on any damage, and just fading, it might be worth a phone call.
    Manager of retail pool location in Ohio
