Thread: SWG Disclosure
    SWG Disclosure
    I am new to this forum and can appreciate the education it provides pool owners. I was wondering if there is a Salt Water Disclosure Form available to inform pool buyers of the pros, cons and maintenance issues of saltwater pools before installation.
    18000 gallon IGP rectangular-ish with attatched spa, pebble tec, pentair 4000 DE filter, whisperflo 2hp dual speed pump, 3/4 hp whisperflo for water feature, aqualogic ps4 controller with SWCG, 48" Guardian Premier pool fence with self closing gate
    Dec 2009
    Central Massachusetts
    2,690
    Re: SWG Disclosure
    I dont understand your question. Who would supply this form?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    22,548
    Re: SWG Disclosure
    Hello Craig and welcome to TFP.
    If you're talking about a pool with a salt water chlorine generator. I've never seen a disclosure form. Maintenance, pros, cons, etc are pretty much like a pool without one. There is a section in pool school strictly for pools with SWG's. What exactly are you looking for?
    Re: SWG Disclosure
    I was wondering if there was some sort of written form a pool builder could provide a customer disclosing side effects, materials not to use and maintenance required if a pool has a SWG. Seems if everything was disclosed up front a lot of the issues posted could be eliminated.
    JoshU's Avatar
    New Orleans, LA
    542
    Re: SWG Disclosure
    Quote Originally Posted by CraigC
    I don't believe we anything like that around here. I'm sure some of the members could chime in with their thoughts on what could or should be included. There are a few builders who read the forums so maybe they will have something to help you with.
    One of the main things I see that some builders, service people, retailers, etc. say is that a salt system will eliminate the need for any and all chemial balancing including pH, Alk, etc. Just be honest with the customer and tell them the true benefits of a chlorine generator while telling them that all other aspects of pool care (pH, Alk, Caclium) still need to be maintained on any type of chemical system including a chlorine generator. The owners manual of a good salt system should go over much of this also. AutoPilot's owners manuals are very informative in this area.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
