Results 1 to 9 of 9
Thread: Does an over-sized filter increase water "turnover rate"?
    Hi... narrowing this down,
    My system has a newer single-speed Hayward 1HP pump with 1.5" plumbing throughout. The old filter was a 36sf Purex DE stainless steel model from the 80s. If I move to a larger 48sf filter, will the turnover rate increase, thus allowing me to shorten my run times during the day?
    Thanks, Jon
    27k 16x32' IG
    30000 gal.
    Pentair 60 sq. ft. DE filter 150 gal. per min.
    IG 20X40 Free Form gunite/plaster
    2 hp Purex pump
    Corona, Ca.
    30,426
    Re: Does an over-sized filter increase water "turnover rate"?
    Not enough to be very noticeable. You will likely notice a drop on your pressure guage which means there is less resistance which means there is more water flow. However, the increased waterflow actually will allow your constant speed pump to do more "work" resulting in slightly more electrical consumption.
    None of these effects should be significant enough to make any real difference.
    The one effect you will probably notice is your water will be cleaner and you can go longer in between cleanings because of the increased filter capacity. Larger filters are always a good thing.
    South Central NJ
    3,192
    WRT to the size, larger is not always better with a DE or sand filter. If he had, for example, a 72 sq ft filter and a 1 HP pump, I doubt he would have enough flow to get a good back wash. If he had a cartridge filter, it would be a different story.
    Scott
    Owner of - PoolGuyNJ LLC
    30,426
    It has been the consensus of this forum and others for years that a larger filter is better in almost every circumstance. Devising a scenario in which that may not be true adds unnecessary complexity to an otherwise fairly simple question.
    Thank you for that information. I found a deal and went ahead and bought a Sta-Rite modular 48sf DE filter. This leads me to another question...
    Is there any way to "count" the amount of gallons being processed by the pump/filter system?... maybe as an inline product located within the PVC connections after the filter?
    Jon
    30000 gal.
    2 hp Purex pump
    Corona, Ca.
    Nov 2009
    Indialantic, FL
    323
    Quote Originally Posted by JWB
    search on Blue-White flowmeter (the Blue-White part is a brand, there are other brands, that's just the one I can recall).
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    22,551
    Here's one place that has the best prices on flow meters I've found.
    Aqua Super Store Flow Meters
    Be sure to look at your requirements and order a vertical or horizontal as your piping runs dictate. Remember, close counts, so if you don't have the exact runs required close is good enough.
    mas985's Avatar
    Pleasanton, CA
    11,741
    As Bama points out, the placement of a flow meter is critical to accurate readings. If you don't have the room for the required straight piece of pipe, the readings can be significantly off.
    If you are just interested in a rough estimate as to flow rate, let me know the model number of the pump you have, filter PSI, ~ how long the runs are from the equipment pad to the pool and the number of runs for the suction and return lines. I can usually get fairly close with just that information and save you a bit of money on a flow meter.
    Mark
    Hey thanks for the info and the offer.
    Raining here in SoCal. Will take some measurements and get back to you when it clears.
    Jon
    30000 gal.
    2 hp Purex pump
    Corona, Ca.
