Thread: New Outdoor Bar/Kitchen Build near new pool
    Dec 2009
    Panhandle, Florida
    8
    It's time for us to design our outdoor kitchen/bar area. Currently we grill our food most of the time. We also use a smoker about twice a month. We entertain a lot! I was thinking we should have a refrigerator, ice maker, grill, side burner (he does use it), and small sink. We do about 8 shrimp boils a year so I am tossing around the idea of the recessed burner for the big pot, but it is not a necessity. I don't know how much we will have room for.
    We have a high grade vinyl siding, but it's still vinyl. I don't want to see it melt! How far away should the cooking elements be from the siding?
    I'm trying to attach photos but when I reduce them to get them small enough to upload they get smaller in size too. I hope they are not too small.
    The space from the back wall of our house to the edge of the pool coping is about 17'5". Subtract from that space to walk between the bar and pool. That could take it down to 12' from the back of the house. The width of the area we have to work with is about 11'. Any ideas on how to set this up? Originally I was thinking of cabinets across the back of the house. Then 3-4' workspace and then cabinets with a back-splash of 6.5" that rises up to a 16" bar hang-over that cuts back toward the house to make sort of a "U" shape. Will that be too tight - too much for the space? Should I do away with the cabinets against the back of the house and just have an "L" shape?
    We have not chosen our new grill yet, but natural gas is piped to this area already so we will be looking for a natural gas grill. What sources have you all found for all your grills and other components.
    We live waterview of the ICW and whatever we do has to hold up in the salt air.
    We will appreciate any guidance you all can give! I'll be trying to figure this one out asap so I won't slow down the decking being poured, although we are considering getting pavers instead of concrete. Regular concrete is $4.75 and concrete pavers are $6.75
    Thanks!
    Kelley
    1st Pool! FL Panhandle. In-Ground Shockcrete Pool, 16 x 32 with 9 x 12 "L" for tanning shelf and steps plus a 10 x 4 spa raised 18" with 6' spillover into pool.
    Srswimsalot's Avatar
    Jul 2009
    Raleigh NC
    46
    Re: New Outdoor Bar/Kitchen Build near new pool
    Put a drawing together so we can see the orientation of the kitchen. Show where you want the grill so we can see how far away from the wall it will be. Put dimensions in the drawing. You can do the drawing in paint and save it as a jpeg. If you get an account with Photobucket, you can just upload your pictures. Copy the IMG image link to your post and the pictures should show up ok. I save pictures on Photobucket at medium size. This will help minimize memory space used on the TFP server.You may want to get the gas line buried before you put down concrete, Deciding on where the grill goes needs to be done soon. You should try to stay 3 feet away from the siding if possible. Just my 2 cents.
    Nov 2009
    Orlando, FL
    25
    IMO go with the pavers, i just like how the look a lot! Making my driveway a circle drive and im thinking about going with pavers for that just for the look cheers!
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,071
    Pavers are the way to go. Of we went with pavers because it was cheaper than concrete and concrete will crack eventually
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
