Results 1 to 9 of 9
Thread: Bought house with pool...what am i working with?
    Feb 2010
    Redlands, CA
    12
    Here are a few pics of equipment. Think there is an SWG in there. Some kind of crontroller. 2 separate pumps i think but not sure why. A big ol filter and a heater not sure if its gas or electric. And a whole lot of pvc pipe.
    Was wondering if anyone could tell me what exactly some of these are and if anything stands out as a piece of junk that ought to be replaced.
    Will post pic of pool with attached Hot tub not sure on dimensions. Water needs a little tender loving care. Pool is only a couple of years old.
    only 3 pics per message more to come shortly
    18000 gallon IGP rectangular-ish with attatched spa, pebble tec, pentair 4000 DE filter, whisperflo 2hp dual speed pump, 3/4 hp whisperflo for water feature, aqualogic ps4 controller with SWCG, 48" Guardian Premier pool fence with self closing gate
    Feb 2010
    Redlands, CA
    12
    Re: Bought house with pool...what am i working with?
    More pics
    Feb 2010
    Redlands, CA
    12
    More pics
    Feb 2010
    North TX
    11
    Yes, can be intimidating. There is a Goldline Aqua-rite swg inline after heater. Is a Goldline Aqua-Logic controller. Can get online manuals at Haywardpoolproducts.com
    Second pump could be for water features or in floor cleaning system.
    Rest of equipment is all Pentairpoolproducts.com
    Whisperflo pumps, 4000 series DE filter, Minimax pool heater.
    Heater looks to be gas, look for gas pipe plumbed to leftside of heater,ankle height.
    Cleaning filter will help in turning the pool around. Plus chemicals
    Mike
    River Brook Pools & Spas, Inc.
    www.riverbrookpools.com
    Guest
    Looks like a great start (pebble bottom and (mostly!) all Pentair equipment)! Some TLC and that will be a beautiful back yard!
    Congrats
    to my untrained eye, all the equipment and plumbing look to be in great shape. Even the water is not too bad, considering the dark pebble surface! This will be gorgeous once you get your water cleaned up... read here for that: http://www.troublefreepool.com/pool-...efeating_algae
    Congrats on the new pool, and welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Looks to be a nice set up
    The one thing the pics don't show is the valve for the filter
    Looks like you had a leak at the motor to pump housing at some point, is it taken care of?
    Thanks for joining us here, you honestly can't go wrong with the good folks here
    Luv& Luk
    -Ted
    Feb 2010
    Redlands, CA
    12
    Thanks for the quick responses.
    Ill take a look at the valve for the filter and I see what you are talking about with the motor to pump housing. The house is bank owned so they have zero clue about any prior history the pump may have had. So I guess time will tell if there is still an issue. Keeping my fingers crossed.
    Richard
    JoshU's Avatar
    New Orleans, LA
    543
    The urls above aren't going to the Hayward & Pentair sites. It should be http://haywardnet.com & http://pentairpool.com.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
