Thread: Broken parts
    jefeyessica's Avatar
    May 2009
    Dallas, TX
    62
    Broken parts
    So I wanted to get a head start on getting our pool ready for the summer - We live in Texas, and it will be warm before you know it.
    I went outside to check on the pump, and to my dismay, I found my little glass backwash viewer broken. I guess 16 degree weather will do that
    I would like to order a replacement online, but don't really know what to search for.
    Also, we thought it might be fun to get in the hut tub. Only, when I tried to turn my jandy valve, the handle broke right off. So I have to order a new one of those too.
    Does anyone know of a good, reputable website that would sell both of those things, or is it better to just go to my local Leslie's Pool supply?
    Thanks!
    14,200 gallon in ground Plaster Pool
    "Titan Vertical Grid Filter" -- Pressure DE, 60 sq ft filter area
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Broken parts
    Quote Originally Posted by jefeyessica
    I would like to order a replacement online, but don't really know what to search for. Also, we thought it might be fun to get in the hut tub. Only, when I tried to turn my jandy valve, the handle broke right off. So I have to order a new one of those too.
    What brand/model of pump do you have? Most Leslie's stores stock only the most common (best-selling) parts, though they might offer to order it for you (at the normal Leslie's mark-up!) Poolcenter.com sells just about everything and you can go to their website and browse around for exactly the part you need. There are many other sites, as well, but take care to add the shipping to the item price(s) to compare the actual prices between competitors. To find additional on-line stores, you can Google the parts (by model with part number) and get a pretty good feel for who is selling what and at what price.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    May 2009
    Dallas, TX
    62
    Re: Broken parts
    I guess I need a Hayward sight glass - but when I search at some online stores, it's hard to figure out which one I need. I did go to poolcenter.com, and was a little disappointed with their $12 shipping fee (that's 50% on top of my cost)
    Also, a Jandy Valve handle. I will do what you suggested, and try to find part numbers to make my search a bit easier.
    For 1 sight glass, and 1 handle, it would be a whopping $34 at poolcenter.com....
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Broken parts
    What model filter / valve is it?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    polyvue's Avatar
    Aug 2009
    1,215
    Re: Broken parts
    Yes, when ordering a single low-cost part from anywhere, the shipping cost in relation to item cost is going to be very high. It's better to group anticipated purchases together -- I try to add on a few items I know I'm going to need eventually (testing kit refills; filter socks; fuzzy tails, cleaner bags and wear rings for my Polaris cleaner, etc.) and hope that I've anticipated well; but sometimes an odd-sized brand-name part that costs 67ยข will require replacement... what can you do?
    As Josh suggested, posting the model of your filter / valve may lead members with the same equipment to provide other solutions.
    __
    Feb 2010
    North TX
    11
    Re: Broken parts
    If the Jandy valve handle broken when trying to turn, most likely internal diverter may have to be lubed(if it is the kind that can be lubed) or replaced. There are o-ring seals inside valve also, that may need some attention. spx710ma part number for sight glass, if Hayward MPV.
    Mike
    River Brook Pools & Spas, Inc.
    www.riverbrookpools.com
