Thread: Aeration comparison
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    Aeration comparison
    Last fall when I was first learning BBB, I was trying to lower my TA. This had me raising my pH through aeration. This was a somewhat time consuming process, and I'd like to speed it up if I could. The biggest issue was a concern that if I started aerating in the morning, the pH would get too high while I was off at work and wasn't around to watch it.
    I currently have an Aqualuminator Fountain (image attached.)
    [attachment=0:3f1c5hgp]AquaLuminator Fountain.jpg[/attachment:3f1c5hgp]
    This provides some aeration, but I'm thinking that I can probably speed it up using something like what Rangeball showed in this post:
    http://www.troublefreepool.com/my-ae...hilit=aeration
    It seems to me that this would significantly speed up the process, but I'd like some opinions before I do it.
    The downside is that I can't just build and test it. Since I have an Aqualuminator, I can't just pull an eyeball and stick something like this in the return. I'll have to hard plumb it this spring before I open. (For those unfamiliar with the Aqualuminator, the light sits inside the return line. The back side of the return line is open to allow the wires to come in. It is an O-ring on the light assembly itself that seals this opening. If you remove the light, you have an open hole in the side of the pool.)
    My idea, if I go ahead with it, is to add a "T" to the return line and add valves that let me direct the return through the Aqualuminator or the dedicated aerator. Would something like this be worth the effort? (Note that all my plumbing is exposed under the deck and is easy to get to. It won't be hard, but...)
    On the other hand, the kids love the fountain, so now that they've discovered it, they want it on all the time. It may well turn out that I'm constantly lowering my pH, and don't need this thing anyway
    Tim
    24' AG Round (vinyl replaced 0909) - 13500 gal - Sand Dollar Filter (150lb) - Dynamo DYNII-N1-1 1HP - Hayward HP380 Heat Pump - TF-100.
    Central Missouri
    Before I speak, I have something important to say.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Aeration comparison
    Quote Originally Posted by TimS
    Having a high PH for few hours shouldn't hurt anything. Scaling isn't an instaneous process and usually occurs over long periods of time. So just lower it back down when you get home. Trust me, I've had my PH too high along with CH for many days without any impact. It just becomes a problem when it is chronic.
    Also, what is the rush to raise PH? Eventually, it should rise on it's own. If it doesn't then your done.
    Mark
    If you have high TA fill water, then it is well worth the effort to install a custom aerator. Otherwise, you probably won't use it enough to justify the effort.
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    Thanks, gang. At this point I won't bother with it.
    Tim.
    Central Missouri
