Thread: I got a wow today
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    I got a wow today
    I had to wait for a plumber this morning, so I went out back and spent some time brushing the pool and checking the chemistry. When he arrived, I led him around to the cleanout, near the pool. He looked at the pool and said, "Wow, your pool looks great! How do you keep it looking so good?" My answer was simply, "Keep on top of it, watch the chemicals. Especially Chlorine"
    It really did look good this morning in the full sun. But the deck was a mess and all wet so I waited to take pictures.
    Once the drain was cleared, there was the usual, "Run a lot of water through this." Well, I ran a lot of water through it - pumped straight out of the pool. About three inches, since it rained a whole lot yesterday. By my calculations, about 700 gallons That high CYA is gonna go down!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: I got a wow today
    ooh, wow, your water does look gorgeous
    Beautiful pool!
    You're done SLAMing when:
    Feb 2009
    West Virginia
    216
    I am SOOO jealous!! (as I look out at the 36" of snow covering the backyard)
    WV Girl
    Custom "L" shape IG gunite pool, 36K gal., main drain, 2 skimmers, 3 returns, hayward heat pump, hayward 1.5hp pump with booster pump, ozonator, 4 cartridge filter.
    one dear hubby, two waterlogged kids, and lots of good times!
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by Richard320
    Nice use of space on that lot! (I'll wager 50 faux-gold dubloons that you live in California?) -- Our backyard is only slightly deeper so we had a few feet more to play with during the design phase (it still feels like it takes up the entire yard). I put the pool as close to the fence as I dared. The inspector grumbled but passed it, after I talked his ear off with the kind of enthusiasm normally reserved for the play-offs about all of the cool drainage I planned to install. A cross-street neighbor installed a 40' lane-and-a-half wide lap pool, very rectilinear, 18" raised bond beam perimeter, slate cap. He likes it... it says "Copia raised-bed herb garden with water" to me. Not unusual in this area to see pools built at zero clearance, right at the foundation footing of a bedroom or kitchen.... if there's a window there it becomes a solid wall to meet code or the pool doesn't get built.
    Oddly similar in a way to the conflation of intersected circles, script and waves I tried to work into my pool design, I think yours is more successful. I like the modest elevation of the raised back wall and the almost Lissajous sweep facing the curvature of the wedding cake steps and bench.
    Anyway, thanks for sharing photos!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Feb 2008
    Denton, TX
    5,061
    That looks mighty fine there Richard.
    I always enjoy it when people come over and ask how I keep the pool looking so good. Then I can represent the BBB!
    JoshU's Avatar
    New Orleans, LA
    543
    Nice work, keep it up...
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
