Thread: Hi from Sacman - new to pool life
    Jan 2010
    Sacramento
    10
    1st Post = 1st toe in the pool
    brand new to pools
    Learning to stay away from the pool shop and spend time on the forum
    Mixing & testing like I got an A in Chemistry - It the results I dont understand yet - just add more bleach - no more Chlorine Pucks
    Learning
    David
    14,500 Gallon, Pebble Sheen, Spa – Jandy inteliflow, Jandy filter, Jandy Heater (Gas) Haywood Color logic 4.5 x 3 - Novice but spending freely
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Hi from Sacman - new to pool life
    Welcome! I'm pretty much in the same boat as you.
    I'm having fun with the chemistry set, too. By the time swim season rolls around, we'll have this down pat!
    Butterfly's Avatar
    South Carolina
    10,045
    Hi David and welcome to the forum
    So, you're in Pool School now, huh?
    Don't worry, you'll get it all figured out and have a wonderful pool.
    Lots of members on TFP to help you along the way!
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Hey David,
    No worries, we were all newbies at one point in time....
    JoshU's Avatar
    New Orleans, LA
    543
    Welcome, let us know how we can help out.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
