Results 1 to 14 of 14
Thread: Can you identify this coating on my pool deck?
    I have an area on my 4 yr old pool that has part of the "coating" coming off of it. This coating appears to be put onto normal concrete probably for slip resistance and it definitely keeps the surface cool in the summer.
    1. What is it?
    2. How do I keep the shown damaged area from getting worse?
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Feb 2008
    Denton, TX
    5,061
    Re: Can you identify this coating on my pool deck?
    Is there any way for you to post a picture of this?
    Guest
    Where are you located? That might help narrow it down.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by simicrintz
    Location is listed in his sig.
    You're done SLAMing when:
    Quote Originally Posted by 257WbyMag
    There are two pictures posted in the original post.
    10,000 gallon
    NC KANSAS44
    It looks like kool deck that had too much water in the mix and they didn't knock it down. It might be just one bad area or could be a wider spread problem. It can be patched.
    Or it could have been caused by me. I had a plastic snow shovel out on that area earlier this winter removing snow. The damage is certainly new (this winter) and small at this point.
    10,000 gallon
    NC KANSAS44
    Guest
    Quote Originally Posted by Butterfly
    I guess it wasn't big enough for my old eyes to see
    You didn't cause it.
    It delaminated from the bond failing. Any bond will eventually fail when exposed to freeze/thaw cycles, its a matter of how many cyles it can withstand. It could have just been that area. You could tap it with the plastic end of a screwdriver to see how widespread the problem is. The sound will be very different where it has delaminated.
    Butterfly's Avatar
    South Carolina
    10,045
    Which is another reason why we like to see locations listed in the profiles!
    ....old-er eyes here, too
    DaveNJ's Avatar
    Toms River, NJ
    520
    The manufacturer site below has patch, and seal products for Kool deck.
    http://www.mortex.com/products/kd.html
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Feb 2010
    Central NJ
    53
    My PB talked me out of Kool Deck - said it doesn't "weather " in the northeast and can't handle the freezing winters. Im wondering if the delamination might be caused by ice?
    Rgds,
    Dominick (Inground Pool Newbie)
    650 sq/ft - 20k gallons
    Free-Form Gunite with Granite Ansylbrite Finish
    40 sq/ft 18' raised spa
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    South Central NJ
    3,192
    The delamination is caused by either water penetration or differences in expansion rates between the deck and the coating and then penetration. Once the coating looses elasticity, it's all over at that location. It is patchable. Eventually though, it will be time to redo it.
    Scott
    Owner of - PoolGuyNJ LLC
    I will say that I am a VERY big fan of the way the deck feels in the summer. I never knew what the product was but we have always been amazed at how comfortable it is to walk on. Even if it is 110F outside.
    10,000 gallon
    NC KANSAS44
