Results 1 to 7 of 7
Thread: auto fill stuck on
    auto fill stuck on
    Have an auto fill stuck on all the time. Was hoping someone coud point me in the direction to fix it. Do not know much about it. Pool is salt so the cap on the end was corroded and when i was working to get a cooter pin out the cap came off and i can tell will have to be replaced but i do not believe that is the main problem. Thank you for your time.
    20x40 40K gal concrete pool, GE pump, sand filter, 40 years old (approximately)
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: auto fill stuck on
    Does yours use a solenoid valve or a float valve?
    Not really sure but i think just a float valve. How do i tell the difference?
    A solenoid valve is an electrically operated valve that turns the water on and off based on a water level switch which may or may not be located near the valve. A float valve is very much like the one inside a toilet tank; they use a mechanical valve operated by a float right next to the valve.
    mas985's Avatar
    Pleasanton, CA
    11,743
    The make all PVC or nearly all PVC float valves such as this that might hold up better with the salt.
    Mark
    All right. thank you guys for the info. i am going to look into the mostly pvc one and see if it will work.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by mx574
    That's the first (come to think of it - only) thing I've replaced on my pool, and less than a month after plaster. My PB told me that the fancy brass ones tend to get stuck (mine had) and said he'd swap it out for a "cheap plastic float valve, because they hardly ever fail." Almost 3 years out and so far, he's been right. I still have the brass float in a box if I change my mind.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
