Results 1 to 7 of 7
Thread: Pool Safety / Lowering Pool Depth
    My elderly parents just bought a new home with an inground pool.
    - Los Angeles
    - Pebbletec finish
    - 3' to 7' deep
    - Two main drains on the bottom and skimmers on the side
    - Attached raised spa that's connected to the pool and creates a small waterfall into the main pool
    They don't swim and will never use the pool but they (and I) are concerned they could accidently fall into the deep end.
    Can I simply drain off about 2 feet of water from the pool to reduce the deep end and still keep the pool running? I assume the pool will just use the main drain to circulate the water and the skimmers won't be in use?
    Would this affect the spa?
    I've gotten different responses from different people as to whether or not this is possible.
    If I could, I'd just drain the whole pool but I'm told the pool might crack if I do.
    Thank you.
    OB Pool - 45K Gal. 64'x25' free-form IG - 35'x18" raised bond beam - Swim up bar w/ 5 stools - 14'x8 ' sunken patio/grill area w/ icemaker, fridge, SS cabinets, sink, granite counters, dual head grill - 14' spa w/12 venturi jets - 2 fire bowls - 1 firepit - Indeck drink cooler - 3 fiberlit waterfalls - 14' sun shelf with 2 fiberlit bubblers - 25 x fiberlit star floor fixtures - 5 Pentair Intelliflow 3HP pumps - Tiger Shark QC Cleaner - 4 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Intellichlor IC40 alt cells - Intellitouch i9 w/ i10x expansion - Pentair IS10 spa side remote - MobileTouch2 - 4 Valve Actuators - Silencer Blower - Pentair 520 Cartridge Filter - 2 fiberlit laminars - 4 Fiberstar Illuminators - Perimeter fiberlit bar counter and spa - 2 Bermuda Skimmers - 8 Returns - Hydrazzo custom color plaster - Natural quartz ledging - Glass Mosaic Tile - 2000 sq ft paver deck w/ double banded poured coping - Interfab G-Force Pool slide.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Pool Safety / Lowering Pool Depth
    Welcome to TFP.
    If you drain 2 feet, the shallow end will then become a danger because there won't be enough water in it to break a fall.
    If they do fall into the deep end, they may not be able to reach the deck to hang on or access the ladder to get out if they are injured or disoriented from the fall, or if the fall was the result of a partially debilitating event.
    The skimmers will no longer function and would allow the air into the pump unless they are plugged.
    The returns will probably be above the water level, making a decent amount of noise, and increasing evaporation.
    You'll have a hard time maintaining the water without operating skimmers to remove debris.
    If money isn't an issue and the pool layout would allow it, an automatic cover might be a potential solution.
    If we get a mesh safety cover, can we still run the pump to maintain the pool? My understanding is that I would still need to circulate the water at least once a day, but I don't want to have to pull off the cover each time.
    Water from the raised spa flows into the main pool via a mini "waterfall like" spout. Would the water just go right through the mesh cover (since I'd have to still run the pumps)? or is a custom cover created with a gap in that location so that water can flow through that area of the cover?
    My goal is to make the pool safe and minimize any maintenance needed.
    Thank you
    Guest
    If you drain it down to any place that the PebbleTec is exposed it will leave a "bathtub ring" that you will never get out. There really isn't any safety in lowering the water anyway, as if they fall in they would not be able to reach the edge from the lower depth, and nearly any depth of water is dangerous if they would be knocked unconscious.
    Maybe you could have a temporary deck built over it. That would protect the pool somewhat, and if they ever sold it would be an asset again.
    Dec 2009
    Central Massachusetts
    2,690
    Those mesh safety covers (like a loop loc) are not meant to be used when the pool is "open" as you have suggested. A motorized cover can be used since it is easily removed to maintain the pool. However, i have no idea how one of those would work with a spill over spa.
    Not to be insensitive, but, if the pool was not something they/you wanted, why buy the house? Having a backyard inground pool is not something you can really neglect, keep water in, and keep covered continuously. They can be winterized for a season, but they really need care and maintenence.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Had you thought of installing a removable fence such as the Protect-A-Child system?
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Is katchakid available in your area?
    Love TFP? Become a
    TFP Supporter!
