Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: I thought I lived in Houston Texas
    Sep 2009
    Spring, TX
    258
    So the rest of the week the highs will be in the upper 40's and lows in the low 30's. Darn groundhog is to blame for this.
    skydiva44's Avatar
    Houston, Texas
    200
    Re: I thought I lived in Houston Texas
    I feel your pain...rain to accompany that cold weather too!
    ABG Easy Set 18 x 48
    5455 gallons
    SWG
    Intex Pump 4000 GPM - Size B cartridge
    Oct 2007
    Valrico, FL
    537
    Someone needs to talk to those darn yankees about sending thier cold air!
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by dschlic1
    It's clear and 32 degrees in beautiful downtown Worcester, MA right now
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Sep 2009
    Spring, TX
    258
    Quote Originally Posted by skydiva44
    What part of Houston are you in? I am in the spring area.
    Feb 2009
    West Virginia
    216
    would LOVE to have your 40 degrees.....as I sit here looking out the window at 30 inches of snow in the front yard......
    WV Girl
    Custom "L" shape IG gunite pool, 36K gal., main drain, 2 skimmers, 3 returns, hayward heat pump, hayward 1.5hp pump with booster pump, ozonator, 4 cartridge filter.
    one dear hubby, two waterlogged kids, and lots of good times!
    Feb 2008
    Denton, TX
    5,061
    40 degrees and raining here...
    Sure, I want to use the pool. But I still can't quite condemn this weather entirely as I cannot forget the 100+ degree day stretches that we no doubt have coming to us in August. Sometimes, it's just too hot to be outside.
    March is coming. Won't be long now.
    skydiva44's Avatar
    Houston, Texas
    200
    I live in the Champions Area, near Northgate Country Club..
    I know we should be thankful we do not have all that snow that you guys have up in the NE, but in Houston....we just don't get this cold of a winter most of the time!
    5455 gallons
    SWG
    Aug 2009
    North Central Texas
    1,358
    Houston weather has been matching Dallas weather, somewhat closely, much of the winter. Very strange and unusual. Way up here in Dallas area we are, I think, two climate zones lower (colder) than Houston. We are 8a, Austin 8b, and I think Houston is 9a (maybe 9b in some micro-climate areas). That's about 10 degrees higher, average low temps per zone, as you go up in numbers. I feel for you guys, really. You all have plants in the ground, that we have to bring in, in winter, that just don't tolerate the colder temps very well. I've had to put frost protection on some outdoor plants that normally tolerate our winters.
    This has been the cloudiest, rainiest, 6 weeks of winter that I can remember since being in Texas since '71. I can hardly use the SolarBreeze (solar powered skimmer) and I'm dying to use it more as it does a remarkable job.
    DH is in the Valley two days a week (way down there on the coast where lots of non-cold tolerant fruits and veggies are grown) . It's been cold many days down there too.
    We have lots of trees budding. At least they like the rain.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    skydiva44's Avatar
    Houston, Texas
    200
    Yes GG...I am hoping my palms make it thru this winter....I have covered them to try and protect them and they still look fine, but the neighbors that did nothing to their palms...well, they are lookin' like they won't be around for summer!
    5455 gallons
    SWG
    Sep 2009
    Spring, TX
    258
    Is that off of 1960?
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    We moved from Orlando to Houston several years ago, and I was amazed that Houston was hotter and more humid than Orlando. Bigger mosquitoes, too. Couldn't buy any cold weather for three years. Wet, sure. the soccer fields on Westheimer were under water half the time, but it was never cold. The neighbors were always telling us about "that big snow a few years ago", but we never saw anything. I don't think I ever turned off the air. Now that we're back in Orlando, Houston is some vast frozen tundra. I mean, its kinda cool-ish in Orlando (sock weather), but geeez! What's the deal?
    skydiva44's Avatar
    Houston, Texas
    200
    Yes, it is off 1960...between Kuykendahl and Veteran's Memorial
    OHM, one good thing about Houston....we do have some AWESOME a/c's! I have been to Disneyworld in Feb. and it was COLD! lol
    5455 gallons
    SWG
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    lionsandtigersandbears
    • Check out the El NiƱo forecast at NOAA's climate prediction center (PDF file).
      Looks like we're in for more strange weather... until possibly April.
    Quote Originally Posted by Mr. Cowardly Lion
    Unusual weather we're having, ain't it?
    • Source: Cowardly Lion, upon noticing the snow falling on the poppy field.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Feb 2008
    Denton, TX
    5,061
    I'll bet that your palms will be okay. Ours seem to make out fine year after year. Now if you have banana trees as lots of Houston Metro folks do, they may or may not handle it so well. The one saving grace for them though is that it has been pretty wet down there and water is the lifeblood of any banana tree, hot or cold.
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by 257WbyMag
    And depending on the type banana plant if you can get them chopped down prior to rotting down to the corm some will grow back. I didn't get my young palms covered in time. We'll see what happens next month.
    I had loads of bananas, until a few years ago. DH hated them, so I eventually, had them all dug up and, yes, the corms were gigantic. It took three strong guys to lift them into the truck. All parts of bananas are mostly water. In years before, I chopped down the ones in ground (these were ornamental) before the first hard freeze and then put down mulch to protect the whole pad from freeze (freeze+water=rot) then covered the whole area with plastic to keep the water from soaking the mother corm and babies.
    Many bananas don't tolerate this, though, so I moved them to greenhouses, chopping them back so they would fit. Some were already in planters, but some I dug up and kept in planter during winter. In colder climates people chop them down to a storable size, dig them up, and store them "bare-rooted", actually bare corm, in a cool, but not freezing, dark location. They go dormant. I haven't been able to do that here, during normal winters, because I don't have any place that stays cool enough through the winter.....normally. The banana is actually not a tree. Once it flowers, whether it produces fruit or not, the plant dies and is chopped down. The corm though, by this time, with adequate care (water and sun and fertilizer), has already produced some babies to replace the main plant. It takes about 18 months for a banana plant to produce fruit in the tropics. Getting fruit in temperate climate is possible, as long as the plant is kept from freezing. It just takes much longer.
    gg=alice
    skydiva44's Avatar
    Houston, Texas
    200
    I have 2 huge Sago Palms...so far so good, keeping my fingers crossed that they survive. We're expecting more freezing temps this week with sleet/snow a possibility. I am so ready for a Pina Colada while floating in my blow up pool!
    5455 gallons
    SWG
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    So beautiful today I decided to clean my filter cartridges. Don't get used to it though. The weather will soon turn crappy and rainy again by Thursday.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by tagprod
    Yesterday, Saturday, was a balmy 41 F, no wind chill and, SUN was out; one of very few sunny days in past two months. I sat out by the pool for a couple of hours soaking up the sun and drinking a wonderful Belgium ale. We got about 18" of snow here (different accumulation amounts all over DFW metroplex) on Thursday (snowed about 20 hours) and electricity out for 43 hours. Friday evening we were able to get out of our drive from back in the woods but the road out to main road was almost as bad. Between four houses we shared one snow shovel. Really nice to be out in the snow with neighbors, kids, and dogs even though we (adults) were working most of the time. Electricity back on yesterday at noon but just couldn't stay inside as it was such a beautiful day. Doggies still romping in 3-4 ft drifts. CRAPPY and cloudy (above freezing though) today but SUN should be out for most of next week.
    We keep 1 lb gas cylinders and some small catalytic heaters so we were able to keep pet snake warm and DH's "control center" (recliner) somewhat warm although he had nothing to control. Small gas burner was first and foremost used for coffee and tea. I got in some much desired reading using headlamp.
    As soon as electric came on it was almost like it didn't happen (no electric). It was an adventure for me but DH was miserable with so little contact with outside world; TV, Satellite, AM radio for weather, and Internet although we had FM reception. This is the wettest, heaviest snow I've ever experienced. It's really sad to see all the beautiful old trees so damaged. We have at least two huge cedars and two old oaks uprooted and major limbs down from many trees. BUT Spring is almost here.
    gg=alice
  20. Back To Top    #20
    Sep 2009
    Spring, TX
    258
    So the next few days for the low will be freezing or below. I guess it could be worse and shut the city down because of too much snow.
