Results 1 to 16 of 16
Thread: New Turkey Fryer
    Ft Lauderdale, Florida
    1,455
    New Turkey Fryer
    After years of Smoked Turkey at Thanksgiving, had some Fried Turkey that a friend made.
    FRIED TURKEY! If you've never tried it, it's not oily or greasy as you would think.
    Crispy skin. Check!
    Juicy. Check!
    Quick to make. Check!
    Delicious. Check!
    No Leftovers. Check!
    13 lb bird...10 people.... Turkey Carcass was all that was left!
    I'll have to take photos of my next Turkey Fry. The instructions called for 3.5 minutes per lb of turkey. That was a bit too long for me. I'll have to try 3 minutes/lb at 350 degrees (unless a more experienced Fried Turkey pro can advise me on this). Gotta use the Cajun Butter Injection marinade, and Cajun dry rub.
    MAKE SURE THE TURKEY IS DRY DRY DRY!!!!!
    Any Suggestions at different recipies?
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,091
    Re: New Turkey Fryer
    This past Thanksgiving DW gave me an early Christmas present and It was a turkey deep fryer. We decided to add a 13lb turkey to our traditional 28lb oven baked, Emril Legassee famous turkey brine to our TK dinner. We normally feed 30-40 closest family and friends and all of the deep fried turkey was consumed.
    General consesus is to do 3-4 deep fried turkeys this year
    Forget the oven baked turkey
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Feb 2008
    Denton, TX
    5,061
    Every year, I tell myself that "next time, I'm gonna fry one." I mean that too. So, come Thanksgiving 2010, I'm gonna fry one. Now you guys need to hold me to this, okay?
    22,553
    I have fried turkeys for years, and yes, they are every bit as good as everyone says they are!
    Having gotten tired of throwing 3 gallons of once used oil away every frying, I found the Char-Broil Big Easy oilless fryer. So I bought one and did some research. I've cooked many things (turkey, hen, roast boston butts and even fish) in it. It's just as good as frying and the additional plus is that you don't have a pot with 3 gallons of hot boiling oil you're trying to place a damp bird into. I figure I have saved about $300 to $400 worth of oil so far.
    I will never naysay frying a turkey. It was the absolutely best way I've ever had turkey fixed and still is. The Big Easy is easier and requires no oil and it tastes the same as if you'd fryed it.
    The best way to tell if the turkey is done irregardless of method is to use a meat thermometer and cook it till it's 180ºF.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,091
    I hear that the oil is good 3-5 turkeys and the deep fryer is great for Low Country Boil and Lobsters which we did 2 weeks ago
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by 257WbyMag
    You are now marked on my calendar for Thanksgiving 2010!
    p.s. isn't it about time you change that line in your sig to try to trip some of us up? I'm watching
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by Butterfly
    Ah yes, it would appear that I do need to pay some attention to that and I will. Watch this space for updates.
    JoshU's Avatar
    New Orleans, LA
    543
    Hey Sean, If you want some good Cajun spice I'll have to send you some stuff.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    1,455
    Brother I am ALL over that offer. I'll e-mail you. Just send me the bill.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Sean,
    As per your cooking time comment, we always ignore the recommendations and take the bird out a minute or two after it starts to float. Always seems to work for us!
    MyBad's Avatar
    Feb 2010
    AZ
    60
    I have been doing them in the smoker, and the old style fryer...propane/big bucket O oil/turkey for a long time....last Christmas saw this one on a TV add, looks really much safer, and easy to use http://www.masterbuilt.com/prod-bbturkey.html
    Looking to build a new POOL
    1,455
    SWEEET.... just Fried a 6 lb turkey breast last night. Leftovers tonight. Still moist and juicy!
    Thanks Josh for the injection marinade and cajun rubs. 3 minutes a lb. just right.
    JoshU's Avatar
    New Orleans, LA
    543
    Quote Originally Posted by Poolsean
    No problem Sean
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    So I'll assume cajun spices from NOLA is quite a bit better than the stuff I'm finding in stores in Canada? lmao.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    1,455
    laugh all you want, you can't beat NOLA cajun spices.
    But of course, the secret ingredient is always, LOVE.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I thought the secret ingredient was Jack Daniels whiskey?
    Oh wait....that's MY secret ingredient, not the turkey rub's...
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
