Results 1 to 12 of 12
Thread: in need of help
    in need of help
    i have a 15ft above ground pool and this year i have drained it twice as the bottom of the pool keeps going dirty and when i scrub it the water turns greenish i am using 20g multi tablets and also chlorine, all levels are as they should be when i test water. i was told to shock the pool every time this apears by the people i got the chemicals off but still there i even added some algaecide to see if that helped and still the same so i begging for any advice as kids are desperate to use it
    Thank you in advance for your help.
    Noctiss
    Read the stickies, linked in my signature.
    Post your numbers and we can help you!
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    hi the test results are ph 7.6mg/l
    chlorine 8mg/l
    alkalinity 80 mg/l did shock the pool a few hours ago though
    Noctiss
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    What are you using to test your pool?
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    test strips that came with the pool last year
    Noctiss
    Is it an Intex pool?
    You need to go to a pool store with a sample of your water, then post the results.
    Hurricane Rita did not kill me, but she killed my pool!
    Intex 36'X18'x52" "elliptical pool"/ Hayward 220 filter/1HP pump 14,364 gal, or so
    Jul 2007
    Hillsborough, NC
    525
    First, the kids can use the pool. If it is algae it is not going to kill them. It just makes the water look yucky.
    Second, where did your water come from? Is it well water? If well, get your water tested for metals. The metals may be reacting with the chlorine. The water turns greenish brown. If metals you need a sequestrant/chelating agent. This is a problem I had. But if this happens only when you scrub it is probably algae
    Third if this is algae (I just got done fighting a serious bloom) the algaecide does squat. if you don't have extras already to get 2 or 3 more filters and some filter cleaner. Then figure out how much chlorine (you can just go buy ordinary bleach) you need to shock your pool up to ~30 PPM. Then run your pump 24x7. Scrub to get stuff off the sides/bottom and shock the pool up to 30 PPM. Hold that level for at least 48hrs, 3 days is better. While the hlorine is up that high there should ne no swimming. Scrub as often as you can and change the filter for a clean one out at least twice a day. I scrubbed in the morning twice about 3 hrs apart and in the evening the same.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Quote Originally Posted by crokett
    Don't swim unless appropriate chlorine levels are holding. Live algae can lower the chlorine level very quickly, making the pool unsafe.
    The level to bring chlorine up to to shock depends on your CYA level. I would not go as high as 30 ppm without knowing your CYA level.
    The best investment in your pool you can make is a good test kit!
    Jul 2007
    Hillsborough, NC
    525
    Unsafe how? I grew up swimming in lakes and ponds that were never chlorinated and I'm sure they had algae somewhere in 'em.
    Edited bb code TMQ
    Not all lakes and ponds are safe. One popular swimming hole where I used to live was closed every couple of years because of disease causing bacteria.
    Living lakes and ponds have active biological systems in them. When things are in balance harmless bacteria out compete the dangerous ones, killing them off. And other organic matter, such as viruses are broken down and used as food. In a swimming pool without sanitizer things are way out of balance biologically and it is quite possible for harmful bateria to thrive and for viruses to survive for long periods. The most common risk is person to person disease transmission through the water, but even if you are the only person swimming in the pool there are other less likely, but still common enough, disease transmission routes (animals, airborne dust, etc).
    Appropriate chlorine levels kill off nearly everything quite quickly, eliminating nearly all of the risk.
    Jul 2007
    Hillsborough, NC
    525
    Good point Jason. I've been swimming in lakes and ponds all my life and never really thought about it.
    Hmm.... Balance huh? Maybe I could get some algae eating shrimp or something to live in my pool?
    Guest
    If you want some reality on unsafe water check the history of the polio epidemic of the 50's. Much of the trasmission was suspected to have occured in public swimming pools!
