Thread: hex nut for fiberoptic lighting
    May 2009
    can anyone tell me the purpose for the flex nut that is installed just inside the lining of the inground pool.
    There's a bubble that seals the light and when I took that off I noticed the hex nut was not on tight.
    Also, what happens if the seal is not on tight-does fiber optic lighting burn out like the regular lighting does?
    The maker of the light is fiberstar.
    Many Thanks,
    30 y/o 16,000 Gal free form IG by Anthony & Sylvan
    48 sq/ft Hayward Pro DE filter
    1.5hp super pump
    South Central NJ
    Re: hex nut for fiberoptic lighting
    Fiber will opaque when exposed to water. This will reduce the light released at the lens.
    Are you doing a liner change?
    Without a pic, I cannot imagine what nut you are referring to. Would you post one or put a link to one that shows what you are referring to?
    Owner of - PoolGuyNJ LLC
