Thread: TC vs FC
    TC vs FC
    I recently ordered and recieved the TF-100 test kit from TFTestkits. The Taylor OTO test kit that was included says that it tests for TC (and Ph but my question is about TC) instead of FC. I thought your daily monitoring would be for FC so you know how much active sanitizer is available in your water. What am I missing here?
    Thanks!
    Chuck
    385 Gallon Hawkeye Venus Hot Tub
    Pump 1-Pentair 2 Speed 4.2HP
    Pump 2-Pentair 1 Speed 3.0HP
    Balboa O3zone Chip Ozonator
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: TC vs FC
    Unless you have a problem, TC is usually very close to FC. The FAS-DPD test is what I use for a weekly checkup test and when I have or suspect a water problem. Otherwise the OTO is good enough.
    Re: TC vs FC
    Thanks for the info.
    Chuck
