Results 1 to 13 of 13
Thread: electricity cost question for VF3050
    I just turn down my pump operation time to 5 hours a day from 9. 14000 gal inground pool.
    I have the pentair VS-3050
    my pool guys set up different speeds.
    2- hrs on 3350 rpm
    3- hr on 2250 rpm
    According to the pump Calculator. I will turn the water once a day and only use about $10-15 a month on electricity?
    Questions
    1. So with SWG will 1 turn per day be enough?
    2. will 5 hour operation a day really be about $10-15 a month?
    14000K gal 400sq ft w 6x8 spa, Pentair Intelliflo VS3050, Pentair cart filter, Pentair Master Temp, Pentair Intellichlor IC40, Pentair Easy Touch 8, wireless control. 3x intellibrite LED light. Pentair Kreepy Krauley Sand Shark. Solar Panel Plumbing. 2 x 24 inch arc sheer 24" spa spill way.
    Vero Beach, FL
    462
    Re: electricity cost question for VF3050
    How long you need to run the pump for the SWG is a not an easy question to answer because there are so many other variables, such as the SWG output setting, the size of the SWG, the age of the SWG, the temperature and chlorine use. I'd start at 100% SWG level and just check the chlorine every day or so and see if you are rising, steady or falling. If falling, then you have no choice but to run the pump longer. You should also repeat this procedure when the temps start to rise because your chlorine usage will increase.
    The actual cost to run the pump can only be estimated with the calculator. Pipe size, length of run, number of elbows, etc. all can make the pump work harder or easier. If possible, turn off everything in your house (fridge, hot water heater, clocks, etc.), run the pump for 1 hour and read the meter to determine what it is actually using.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    my SWG is a Pentair IC40. I looked at the easy touch panel and setting says 50% for intellichlor. Salt was just introduced to the water, 1st week fo SWG operation. The PB is still taking care of the water since I didnt get the " Pool School " class yet.
    Nov 2009
    Indialantic, FL
    323
    I don't actually have a pool or VS-3050 yet (just signed the contract a few days ago), so take my words with some caution.
    However, the 2-hour run speed seems to use a very high RPM value. Of course, without knowing the flow rate demands maybe I'm missing the point. The Pentair manual implies that with 80 feet of head you would be producing 95 GPM flow rates - which is quite high for a salt system as well (according to my readings).
    Second, I was under the impression that lengthening the time, at lower RPMs, would make for greater electricity savings than high flow rates for shorter times.
    Somebody please correct my understanding where I have errors - I would hate to take bad thinking into pool ownership.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    mas985's Avatar
    Pleasanton, CA
    11,741
    If you can tolerate lower flow rates, I would have most of the run time around 1000 RPM as that seems to be the most efficient setting for the Intelliflo. You should never need to run the pump at 3350 unless you are trying to run spa jets or a large waterfall. Even 2250 is on the high side but it may be needed for a cleaner or decent skimmer cleaning but you shouldn't need to run it more than a few hours at that rate.
    These are guesses but at 1000 RPM, you will use about 1100 watt-hours per turnover (8.5 hrs) and at 2250 RPM, you will use about 2800 watt-hours per turnover (3.5 hours). So as you can see, it is much more beneficial to run at the lower RPM if you can get away with it.
    Mark
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,068
    If you have a small pool like we do it is more beneficial to have a one speed pump. I run our pump for 1 -2 hrs a day and have the SWG presently at 5%output. When we were swimming last year I set the SWG to 50% and still ran it 1-2hrs per day. My electric went up about $10- $15 per mth. In my case it is not a cost savings to use a VF pump because it will never pay for itself VS cost of the pump Just my opinion
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    found this video. I understand now.
    [youtube:afsxzj1r]4dIz4R-1d2k[/youtube:afsxzj1r]
    I should prob run the pump 2 hrs at 2000 rpm or so for the cleaner then set the pump to about 750rpm for the next 6 hrs.
    I may need a separate program for Solar heating later.
    Does anyone know the flow rate I need for Solar panels?
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by fkong777
    Lots of good information on solar panel utilization here:
    solar-panel-technology-comparisons-t9648.html
    In particular, read this post:
    viewtopic.php?p=77354#p77354
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    mas985's Avatar
    Pleasanton, CA
    11,741
    A decent rule of thumb is about 1 GPM per 10 sq-ft of panel +-.
    Mark
    Aug 2009
    North Central Texas
    1,358
    [youtube:wkk70wm0]4dIz4R-1d2k[/youtube:wkk70wm0]
    Thanks so much fkong for posting this.
    WOW..... this video is fantastic. KISS Keep It Simple Stupid Makes me feel a whole lot better about my very recent purchase of Intelliflo VF. (It's so cold and rainy/icy I'm going to have to delay installation even more.) If the Aquabot Turbo, separate drive powered rather than all water drive power, drive motor+water pump Aquabot vs one pump for jets and driving Verro, (used and on its way to replace Verro 300 (similar to Aquabot Turbo T-Jet) can make it up my steep slope when silt bag is used and beginning to clog up, I'll be saving boo-koos of $$$$, even with our somewhat good rates here, running the VF virtually 24/7, maybe less, for filtering vs my current pump running the 1.5 hp (SF 1.5), which is somewhat a 2.25 hp pump, for 12 to 24 hours per day. And eve if I have to run the main pump higher speed/flow for pressure Polaris I bet I'll be able to run it for much less cost than old pump. I don't have any complicated water features until I add solar (hope, hope, hope I can swing it this year).
    I'm also feeling better about the more costly VF over other pumps for when I put in solar heating. All I'll need is a simple inexpensive, actuator/timer to open valve for solar and VF will adjust the speed/flow. Come on weather...... heat up some.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    It seem i need at lease 1600 rpm for the intellichlor to not tag red light on "flow"
    so now I set the pump to run at 2250 rpm for 2 hr and 1600rpm for 5 hrs a day.
    mas985's Avatar
    Pleasanton, CA
    11,741
    You might be able to lower the RPM if you adjust the bypass loop flow rate valve so that more water goes through the cell.
    Mark
    i dont have a bypass loop on the SWG.
    BTW at 1600rpm my Sand Shark automatic cleaner is useless. and at 2250 the sand shark works very slowly and it wont climb the walls anymore.
    That's what I get for having a 35feet run to the equipment pad which I located out of site from the pool.
    That video is somewhat misleding.. Not too many people have a short pipe run to the pump.
