Thread: Equipment set - is this an okay filter location
    I don't quite have enough space to get all the equipment in one spot. There is a walkway to the gate that I need to maintain at a certain width. If I push everthing down, away from the fence, the heater sticks out into the walkway too much. Is there a maximum distance that the filter should be from the rest of the equipment? I would like to keep it where it's at and make a small cut in the concrete near the filter, tunnel under the walkway and pop back up to the pump and heater on the other side where there will be another cut in the concrete. Does anyone see any issues with this?[attachment=1:8aqx03m4]SAM_0098 - Copy.JPG[/attachment:8aqx03m4][attachment=0:8aqx03m4]SAM_0096 - Copy.JPG[/attachment:8aqx03m4]
    15,000 gallon gunite pool, grey plaster with 8' raised spa
    Jandy PlusHP Pump 2 HP Dual Speed
    Sta-Rite 450 Sq. ft. Cartridge Filter
    Cleva-Chlor RP40HD
    Raypak 400k btu heater
    Jandy Aqualink RS-8 One Touch
    Savi Melody 12v LED lights
    Guest
    Re: Equipment set - is this an okay filter location
    Shouldn't be a problem with the filter there (unless you don't want to see it when you open the blinds on that window!), but I question the heater placement. How far is that off of your property line? I can't see from the picture but it looks like you may be up against a fence (heaters have to be 12" away from combustible materials also), and that fence may be property line?
    Use big pipe (2 1/2" would be nice, or bigger)and that will help make your plumbing more efficient. Keep your 90's to a minimum. Other than that, no real reason why the filter wouldn't work like you are considering (unless you don't want to see it when you open the blinds on that window; did I say that already??!).
    Great news. Thanks a lot. That's just a bathroom window so I'm not really concerned with having a view while I'm in there, lol. And no, that's not a property line behind the heater. It's just a shed. I will ensure that it is 12" away. And the fence and gate is just a secondary gate between my sideyard and my backyard. The pool will be just on the other side. Fairly short plumbing runs and keeping the equipment out of sight.
    Cleva-Chlor RP40HD
