Thread: Copying pictures??
    Jan 2010
    Northern Virginia
    282
    Copying pictures??
    I'm in the very, very early stages of planning a pool and I wanted to gather pictures of good ideas or things that I might like, but I can't seem to copy pictures out of the fourm into a Word document. Usually I just right click on the picture........copy and paste and it shows up in the Word doc, but that doesnt' seem to be working for me.
    What am I doing wrong? How do I copy pictures?
    Thanks!
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Copying pictures??
    Quote Originally Posted by Bart
    Thanks!
    Welcome to the forum
    If you can see a picture in your browser you ought to be able to right-click, copy and then paste into a blank Word doc. What browser/version (IE, Firefox etc.) are you using, which operating system (Windows Vista, Apple, etc.) and what version of MS Word?
    In Windows, of course, you can also use screen print (Shift-Print Scrn, then paste from the clipboard into Word, then edit the picture to trim off parts you don't want) but it's a heavy-handed way of just grabbing a single photo.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jan 2010
    Northern Virginia
    282
    I'm using IE 7, or whatever their latest version is.
    Funny thing is, right after I posted, I tried to copy another picture and I could do it as it normally works, but when I went back to the original picture I wanted, it wouldn't let me copy it. So it seems like some pictures are posted in such a way that allows them to be copied and others give me trouble.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    If they are displayed using Flash, you'll get the Flash menu which doesn't allow copying.
    Quote Originally Posted by JohnT
    At which point you would probably want to learn about the Alt/PrintScreen method. Alt/Printscreen, open paint or photoshop or similar, paste then crop. You now have it.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    polyvue's Avatar
    Aug 2009
    1,215
    I'd forgotten that some web sites try to prevent copying of images through various tricks or, as John said, use proprietary software such as Flash. If you want the picture badly enough there are many ways to get around this, the easiest way described above by Thinkly.
    __
