Results 1 to 10 of 10
Thread: pool aid
    Jan 2010
    Murrieta, CA
    9
    pool aid
    greetings tfp i'm rob. my problem starts just after the socal rain that occurred last wed. we just moved "3rd owner" and we don't know about general pool maintenance. but as you can see it's green and would like to start here. later on.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: pool aid
    Welcome to TFP.
    Start out by reading Pool School. If you have questions, post away.
    Re: pool aid
    Welcome.
    In addition to the reading that JohnT suggests, which is a great idea, posting a full set of water test results would be very helpful.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: pool aid
    Quote Originally Posted by deejjoy
    Welcome, Rob
    The article, Defeating Algae provides a nice overview of how to approach this....
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jan 2010
    Murrieta, CA
    9
    Re: pool aid
    question, i have a tarlor k-2005 but i'm missing cya dispensing "7ml-14ml" bottle for testings and need some sort of trick of the trade. also for shocking the pool can i use my swgs rig to add chlorine along added d.e?
    my water test result is noobish so go easy on me.
    FC: 0
    pH: 8.0 <---alittle darker
    TA: 90
    CH: 20 - after adding 20xr-0010 and 5xr-0011l the water color a light pink or from color sample reading between 2&3 in Br. next i follow through with r-0012 by 10 and doesn't turn blue so thoughts are high in CH? so i tried smaller 10ml test and added 5 drops, i know i know my fault not swirling after a drop.
    CYA: n/a
    Re: pool aid
    From what you said, it sounds like your CH level might be 125, but you didn't explain what you did clearly enough for me to be sure. CH certainly isn't 20. It is very common for the CH test to take more than 10 drops of R-0012, twenty, thirty, even forty drops are all fairly common. You should do that test again and be patient and see how many drops it really takes to turn blue.
    Before fighting algae, it is best to lower your PH to around 7.4. You don't need to hit a PH of 7.4 exactly, anything from 7.2 to 7.6 will be fine.
    Getting a CYA reading is important. If all you are missing is the mixing bottle, it is fairly easy to rig up something else. You just need equal quantities of pool water and reagent and a way to pour it into the view tube fairly slowly. If you have a dropper bottle that is empty you can figure out what half full is and mark it and then use that, or rig something else up.
    Chlorine and D.E. have nothing to do with each other. I get why you are asking about chlorine, but I don't understand the reference to D.E. Perhaps you could explain that.
    A SWG is not suitable for shocking. When shocking you need to add chlorine very quickly to get up to shock level. A SWG is designed to add chlorine slowly, which isn't what you want. You can use the SWG to supplement the chlorine you add manually. Bleach is usually the simplest way to add chlorine quickly. Be sure to get a CYA reading first, so you can calculate the amount of chlorine to add.
    Jan 2010
    Murrieta, CA
    9
    Re: pool aid
    so once i have proper ph/cya readings i can add right x amount of chlorine to my pool but before that you mentioned d.e has no part other from what i partially know that it helps in filter department but where do i add d.e too. argh once i get this far i should be on track.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: pool aid
    You should take a look at this article:
    http://www.troublefreepool.com/use-a...ers-t4086.html
    Jan 2010
    Murrieta, CA
    9
    Re: pool aid
    before promptly taking actions should i wait until spring. thank you guys, the pool school well planned for newcomers like me.
    polyvue's Avatar
    Aug 2009
    1,215
    Re: pool aid
    Well, of course that's up to you but spring comes fairly soon in Southern California. Recommend not letting your water get to 65 or 70 before taking action. It will still be possible to clean up a mess but it will take longer...
    __
