Results 1 to 13 of 13
Thread: Fish Eye Returns Maintenance
    Fayetteville, Arkansas
    220
    Does anyone know of a technique to smooth up older fish eye returns so they swivel smoothly again?
    Paid $8 for one today at the pool store - Hayward.
    Thanks !!
    Chris
    20x40 30,000 gal IG Liner, Pentair II Sand
    Jul 2007
    ontario, canada
    82
    I was going to wait until tomorrow to ask pretty much the same question. After reading all the opinions on return positioning on another thread I tried to move mine only to find that one of them won't budge.
    Good question.
    N
    [color=#0000BF]16x32 inground vinyl liner approx 23 000 gallons
    22" cyclone sand filter, 1 HP pump
    solar cover, solar heating panels
    Taylor K-2006 test kit
    30,431
    Ranger & Survey,
    Yeah, that's an issue I struggle with, too. Be sure you loosen the threaded retainer ring prior to adjusting the eyeball....it's the only way I've found to make any adjustments.
    If it helps to wax the eyeball or something, I'd sure like to know....I frequently adjust mine and it's a minor pain.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    what about a thin layer of that silicone lube we use on the pump lid?
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    mbar's Avatar
    Ashland PA
    257
    I have loosened mine up by soaking it in vinegar. I did put a little wax on it then, and it works fine.
    16x33 fiberglass pool sand filter
    220
    Quote Originally Posted by mbar
    Interesting ... I'll give it a try. Thanks
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    are you talking about these things?
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    mbar's Avatar
    Ashland PA
    257
    Yep
    New Brunswick Canada
    819
    If you wiped them with Acetone, it will disolve a small amount, thereby reducing the friction
    Jun 2007
    SF Bay Area
    441
    What do you use to loosen/remove the eyeball retaining ring? I have been using large water pump pliers, but this leaves quite a few gouges in the plastic retaining ring,
    Is there a special wrench with the required jaw opening of 2-3/8 inches? Or do you use a strap wrench? Or just fabricate a wrench out of 3/8" plywood?
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    mbar's Avatar
    Ashland PA
    257
    I can just turn them with my fingers and get them free. Once out, if the eyeball is stuck, I soak the whole thing in vinegar till it moves freely.
    I use a strap wrench if they won't turn by hand. I have never had any damage to the plastic that way.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I've found that putting a latex glove on before trying to turn the ring helps me get a better grip. I've never had to use any kind of wrench on them.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
