Results 1 to 19 of 19
Thread: Hayward pump died, needs rescusitation.
    Man there is a forum out there for everything. I'm expecting this one is as helpful as the others I visit now and again.
    Anyway, I live in north Florida and the 4" of rain we got over the course of an hour left my pool filthy and my pump dead. I've already removed it from the system, but when I first attempted to restart it, the breaker had tripped, so I flipped it back. There was a brief spark at the end of the pump and the breaker tripped immediately.
    I am rather handy and am keen to learn and save some money, so I'm hoping you guys can walk me through the diagnostics and repair on this. The pump is a Hayward super pump with an AO Smith motor. My best guess is that the pump is 6 - 10 years old.
    TIA,
    Pool Noob
    edit: I am concurrently making full use of the search function
    Kidney pool with liner, hayward(dead) 1hp super pump, hayward sand filter, goldline SWG, polaris cleaner. No idea on volume.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Hayward pump died, needs rescusitation.
    Welcome to TFP!!
    While I'm not 'the expert' to answer this, you might try changing out the capacitor Capacitors are fairly cheap and easy to install.
    Just to check, there isn't any 'grinding' noise when the pump runs? Or leaks under the pump housing?
    I believe that it's the capacitor, but the more info you can give us, the better we can help resolve the problem
    Luv& Luk
    -Ted
    There wasn't any running to speak of. It looked more like an arc and then immediate breaker trip. I only flipped it two or three times over the concern of burning up the timer. Tomorrow or Saturday I'll take a better look and see if the motor spins free or any grinding or otherwise.
    There is a chance that the water rose enough to submerge part of the motor, but again I can not verify till later, it was at least 4" over the TOP of my pool and my liner had already been floated during hurricane faye. Its too dirty right now to tell if its worse or the same, but that is another matter. I didn't notice any water in the housing when I moved the pump from the slab.
    I had another 1hp pump for a hot tub I got for free, but when I tested that one, it would spin up for a second or two, then trip the breaker. I'm starting to suspect the breaker except for the sparks I'm seeing in the original pump.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    If it's arcing inside the windings then you'll need a new motor. It's possible that there's a loose connection in there somewhere though, around the cap as Waste mentioned or perhaps on one of the wire terminals.
    22,553
    I've seen the wiring terminals get loose and arc, so it could be that. The centrifugal switch will arc too but you normally can't see that. If the cap's shorted out it'll cause the switch to arc and smoke.
    got a verbal quote for rebuild of my existing motor, bearings, contacts and windings for $160. I think I'll just get a new two speed motor instead. Can someone point me to a how-to on installing a two speed in place of a single and what gaskets should be replaced at the same time? Also, I've seen some people say they need to replace the impeller to match the new motor?
    edit:
    Conclusion - After much searching of the web, I've determined that I can in fact replace the single speed pump with a two speed pump so long as the HPxSF >= the one being replaced. The existing pump is 1HPx1.1SF=1.1BHP, the replacement I'm looking at is a STS1072R .75HPx1.5SF=1.125BHP. I've found it for $196 + $30 shipping. Have to order the seals from somewhere else though.
    How important is the PS-3868 ozone/salt shaft seal compared to the PS-200 standard shaft seal?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    I don't know what the cost difference is between the seals, but I don't think you'd see an appreciable difference. I use standard seals on ozone/salt equipped systems and have never noticed a difference in lifespan.
    South Central NJ
    3,192
    I wouldn't pay more for them. If they are the same price, I might consider carrying a set on my truck.
    Scott
    Owner of - PoolGuyNJ LLC
    Thanks guys! Should be getting my motor in today and maybe have clear water again in a week, glad its not summertime
    well, I finally got the motor installed, waiting for the glue to dry and then I'll turn it on. Guess an episode of Legend of the Seeker will give me plenty of time.
    Man this things runs GREAT, till the impeller shaft breaks. Think it might be due to me running the pump with NO water in it thinking it was 'self priming' it wouldn't be a problem. So, I'll pick up another impeller and shaft seal. AHHHHHHH
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by lonesouth
    Big ouch! But just think of all the experience you're acquiring while attending classes in the infamous School of Hard Knocks!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    South Central NJ
    3,192
    Been there and graduated. I even taught them a few things!
    Scott
    Got the new impeller and installed the shaft seal the CORRECT way with the ceramic side on ceramic side. The new impeller has a brass stem and seems to be better constructed. The pump is up and running and works great. Incredibly quiet and NO LEAKS!!! I tossed in 3 bags of shock and 240lbs of salt, hoping the water will clear up in a week, we'll see. It was a great shade of green/brown.
    South Central NJ
    3,192
    It will likely need a vacuuming. If there is a lot of scuzz, vac to waste, which means holding off on adding the salt. Alas, too late for that.
    Adding the shock only kills the algae, doesn't remove it.
    Scott
    Casey's Avatar
    SW PA
    10,461
    Now you can read-up on Pool School and use BBB instead of bags of shock.
    Pool School is located on the top right of every forum page and in my siggy.
    Hope you have an uneventful summer after all your pump woes! Good Luck and welcome to TFP!
    Thanks for the advice, I'll be going to pool school for sure! I went ahead and added the shock and salt in hopes of having at least clear water soonish. From what I can tell so far, running the leaf net around, there aren't many leaves in the pool, mostly dirt and film. The salt came up to 2400 PPM, enough to generate, and I'll pick up two more bags on the way home. I need a new pressure gauge, but I'm figuring on backwashing about once a day till the pool is clear. Checked on the pump this morning and it is happily humming away, at some point I'll need to add the wiring for the two speed switch, but I'll start another thread for that.
    ...and now the booster motor has seized and the whack-it-with-a-2x4 trick didn't work...fun fun fun, i love my pool.
