Thread: Purex Triton Ultra Flow pump screamed and cut off
    Jan 2010
    During the recent freeze(20's) a customer's purex triton ultra flow pump started screaming and would cut itself off while the pool switched pool/spa modes. This pump acts as the spa booster pump, as when it is on, so are the bubbles in the spa! After the second cut off and restart, my customer killed the power to the entire system. He didn't see smoke although he said the motor was very hot. Because of the freezing weather, to get the other water circulating, i walked him through disonnecting the power supply and ground wires so we can turn the rest of the system on. Because i am not very experienced with servicing a wide variety of equipment, I am curious if this typical pump/motor failure and what signs can i look for to determine why it failed?
    I was told that the pump was screaming, similar to what I've read bad bearings sound like. I want to try and determine the options as far as likelyhood of a dry run warping the impeller, or possible motor bearing failure. Is there a troubleshooting manual or owner's manual I can download? I get pump'motor mechanics in general, so a trouble-shoot, first this, then this is ideal for my situation!
    Before I tear it apart to see if it is just the wet end and replace what is damaged, i want to make sure that I wont still have to replace the motor as well, which may end up costing the customer more than the installation of a new pump. I know this is opposite modern business profit strategies and mean to my back pocket but these are good people, so any help is greatly appreciated!
    7600 gal, IG rectangular, SWG wood-fired pool heater, solar heating (pool not too warm, hot tub too big)
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    Re: Purex Triton Ultra Flow pump screamed and cut off
    Quote Originally Posted by Pr0tect0r
    I couldn't find one via google search, just an exploded-diagram for parts: ... parts.aspx
    See also - they have some fairly competitive retail prices on parts and pumps.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
