Thread: Low Voltage Light - Electric cable need to be in a conduit?
    May 2009
    Seminole, FL
    71
    Apparently the landscapers when they were fixing the sprinkler system partially cut the wire going to my pool light. (This was from before I bought the house so I can't make the sprinkler people fix it). Currently it looks as though its running underground through a metal pipe. I can't pull the cable through to replace it so I am going to yank out the pipe and replace the wire. I was wondering if low voltage (12V) pool lights need to have their wires in some sort of conduit or can a wire just be buried like it is for my sprinkler system?
    ~13000 inground plaster
    150sq Ft Cartridge Filter
    Guest
    Re: Low Voltage Light - Electric cable need to be in a conduit?
    It is a non burial cable. It is fine on/in the dirt.
    22,553
    Hey Bruce! Don't you mean direct burial Otherwise you'd have to run it in conduit.
    Guest
    Yeah, I did I meant to go back and change it (I knew it wasn't right when I posted it but couldn't remember the correct term! I've thought about it a couple times since but have been too lazy to go back and edit!).
    Thanks for adding embarrassment to my procrastination
