Thread: Blisters on interior shell
    Nov 2007
    Chattanooga TN
    Hello. My Caldera hot tub is just over a year old and has developed two small blisters on the interior shell surface. It was installed correctly and the water chemistry has been maintained with Caldera's chemicals. I've looked online and found where someone said it's a company defect where the acrylic is delaminating and that you could use a hair dryer on the high setting until the blister becomes pliable and then pin prick it and use hand pressure to release the air behind it. Has anyone else had this problem? If I just leave it alone will it get worse -- crack -- develope a leak? Thanks in advance for any help and/or advice you can give me.
    IG Vinyl 16'x32' - 17,829 gallons
    Hayward 1 HP Super Pump & Sand Filter
    Barracuda G3 Automatic Inground Pool Cleaner
    TF-100 kit - Caldera Aventine Spa
    Re: Blisters on interior shell
    I think you are supposed to drill a small hole in the blister and then heat it up. Never done it so maybe someone with real experience might help. I have heard its like a cyst and you drain out some stinky stuff before reattaching. ???
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    Do you know what model it is? All Caldera tubs except the Aventine / San Gabriel models have >1 yr warranties on their surfaces. There's no great solution. Messing with these things tends to make the problem worse. The acrylic layer is very very very thin and delicate, and putting a hole in it invites water behind it which can make the blister end up larger than it was to begin with. If it's still covered hound them like **** until they replace it for you.
