Results 1 to 7 of 7
Thread: Coping paint?
    May 2009
    Topeka, KS
    81
    Coping paint?
    Last fall I removed all the alum. coping from my 18x36 buster crabbe inground pool. I've sandblasted 2 of the 50+ panels..... I planned to have them powdercoated. No I think I better ask the pro's. What would you suggest? Keep on my powder coating track or use some sort of pool paint? Summer will be here in like 5 months. Thanks! Jason.
    18x36 Buster Crab in ground, 3' shallow 8' deep, Hayward super pump, 300lb sand filter.
    South Central NJ
    3,192
    Re: Coping paint?
    Powder coat, when flexed, breaks. I doubt it can be reattached in such a way to prevent it. Powder coats are heated to melt them. This may cause warping.
    After sand blasting, spray with primer and Rustolium.
    Scott
    Owner of - PoolGuyNJ LLC
    30,402
    Re: Coping paint?
    Powder coating is probably the toughest, most durable finish you can apply. I don't know how ridgid the coping is prior to installation but, once installed, I can't imagine a better finish.
    I would suggest taking a piece of the coping to the powder coating applicator and get their opinion and/or warranty.
    May 2009
    Topeka, KS
    81
    Re: Coping paint?
    I have a friend who works for a Powder Coating Company. They will do them for 1.00 a piece. So I'd have 60 bucks invested or so.... I think the coping is pretty sturdy, I don't think it would bend or flex at all. Painting them at home would be easier and much easier to touch up later on.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Coping paint?
    I give a quick 'primer' on coping painting at the bottom of this thread.
    If I read this thread correctly, you'll need to remove the coping from the pool to get the powdercoat applied. If you do this, please make a diagram and # the pieces so that they go back on correctly (probably some pieces were cut so that they fit around the pool correctly, if you don't, the coping might not go back on the right way.)
    Luv& Luk
    -Ted
    May 2009
    Topeka, KS
    81
    Re: Coping paint?
    I numbered them!! LOL
    May 2009
    Topeka, KS
    81
    Re: Coping paint?
    Progress continues I started sanding with my DA Sander and it's working really well. Hope to post some pics soon.
