Results 1 to 15 of 15
Thread: Pool Pump Energy Cost Comparison
    mas985's Avatar
    Pleasanton, CA
    11,726
    After seeing several questions on pool pump efficiency and energy cost comparisons, I thought it might be helpful to put together a simple spreadsheet that allows a pool owner to compare the costs of several pool pumps. This spreadsheet uses the data from the California Energy Commission web site which shows the energy efficiency of many different pool pumps.
    Warning!
    The following pumps seem to have errors in the database so do not use the profiles for these. Once the CEC fixes the data, I will post an update.
    WFE-2 - Curve-C watts appears to be incorrect. It is too low.
    WFDS-3 - Curve-A watts should read 1570 not 1750.
    WFDS-4 - All of the wattage data is incorrect. It should be the same as WFDS-26.
    WFDS-8 - Curve-B watts should read 1874 not 1784.
    CHII-N2-2-1/2A - Curve-C Wattage is incorrect.
    Testing Documents
    http://standards.nsf.org/apps/group_pub ... %20CEC.pdf
    http://standards.nsf.org/apps/group_pub ... nt_id=8332
    A pump cost comparison spreadsheet may be obtained from this web site: Energy Efficient Swimming Pools
    Mark
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    1,938
    Re: Pool Pump Energy Cost Comparison
    Hi Mark this is great data, unfortunately I do not see my pump model listed. My pump is a StaRite model P2RA5F, 1.5 hp. Do you know which model I could substitute this for????
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    mas985's Avatar
    Pleasanton, CA
    11,726
    The JWP5FL-6A1 should be close enough.
    Also, I found an error on the Scenario2 tab so delete that tab and duplicate Scenario1 if you need to.
    Mark
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by mas985
    Inputs
    2) Pluming Curve - Curve A is equivalent to 1.5" plumbing with single runs but it is probably the closest to most plumbing systems although it is a bit pessimistic on energy efficiency. Soon the CEC will add Curve C which is equivalent to 2" plumbing.
    Pretty nifty table for a quick comparison of pumps. I have a couple of questions:
    I.) The "Pluming (sic) Curve - Curve A" is selectable across row 2 --- should the drop downs for columns C, D & E also be used for input? They seem to work independently: though they are greyed out, one can select Curve A or Curve B in any of the columns, changing the output.
    II.) In the post you've documented both Curve A and the vaporware-like Curve C, so what does Curve B apply to?
    Thanks ---polyvue
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    mas985's Avatar
    Pleasanton, CA
    11,726
    Currently, all the columns are tied to column B for the plumbing input to force the same plumbing for all pumps. You can select a different plumbing for each column but I saw no reason to do that. If you are comparing pumps, they should all be on the same plumbing.
    Curve A is approximately equivalent to a pool with 2" suction/pad lines (or 2x1.5") and 1.5" return lines with 55' runs. Not too unreasonable but still not a great design.
    Curve B is approximately equivalent to a pool with 1.5" suction/pad lines and 1.5" return lines with 190' runs. I'm not sure why on earth they even put Curve B in that table but is a worst case.
    Curve C is approximately equivalent to a pool with 2.5" suction/pad lines (or 2x2") and 2" return lines with 100' runs. More reasonable but may take some time to collect the data so it could be a while before they have that.
    Mark
    polyvue's Avatar
    Aug 2009
    1,215
    OK. But the data for Curve C doesn't yet exist, right? So, little help there. And what makes those yokels at CEC believe that a typical home run is 100'?! I think 20' is pushing it on my system. Would think they'd have at least halved this figure to a more reasonable 50'...
    For precision, I think I'm going to have to go back to some of your original calculations -- will mull these over and get back to you. Thanks!
    __
    mas985's Avatar
    Pleasanton, CA
    11,726
    You could just bump up the efficiency some to approximate Curve C. I estimate that the efficiency should increase by about 15% for Curve C over Curve A. Something better than Curve C might be 20% over A but I doubt it would get much better than that.
    I will update the SS to allow you to add or subtract efficiency.
    Edit - Updated
    Mark
    mas985's Avatar
    Pleasanton, CA
    11,726
    Updated the spreadsheet to use Curve C which is extrapolated from Curves A and B.
    I also added a way to change speeds for a variable speed pump.
    Mark
    no-mas's Avatar
    Jun 2008
    FL
    405
    2) Relative Pump Speed (%) - Used to change a pumps speed from the nominal. However, it is best to use a low speed profile for two speed pumps instead of using this parameter.
    Mark, this grid is great - thanks for sharing your work with us!
    Regarding this statement, if I wish to compare my current pump (Pentair WF28; ss up rated 2 hp, unlisted in your ss) to the two speed version (WFDS28), would it be a reasonable to simply compare the WFDS28 high speed to the WFDS28 low speed? Further, should the relative pump speed be left at 100% for both high and low?
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    mas985's Avatar
    Pleasanton, CA
    11,726
    Nominal speed is what ever the profile dictates. So 100% for high speed profiles is 3450 RPM and 100% for low speed profiles is 1725. You can set 50% on a high speed profile and it will approximate the low speed profile but using 100% on the low speed profile will be more accurate. The speed parameter is mainly for the variable speed pumps.
    In your case, since there is no profile for a WF28, you can use the WFDS28 high speed profile as a proxy. However, you might still want to have three separate profiles for comparison. For two speed pumps, it is likely you will split the run time between the speeds so for example, you could have the following profiles:
    Profile 1: WFDS-28 (HIGH SPEED) @ 1 turnover per day (reference pump)
    Profile 2: WFDS-28 (HIGH SPEED) @ 0.5 turnover per day
    Profile 3: WFDS-28 (LOW SPEED) @ 0.5 turnover per day
    You then add the cost of 2 & 3 and compare it to 1. Also, you can split the run time anyway you want for profiles 2 & 3 but it is more realistic to model it this way. Also, if you split the pump cost between the run times proportional to the run time, then you can just add each of the cost parameters for the two speeds and the totals will be correct.
    I updated the spreadsheet with a two speed summary to show you how to set it up (see Scenario #1). Also, I had to fix the run time calculation as it didn't take into account the turnovers per day.
    Mark
    mas985's Avatar
    Pleasanton, CA
    11,726
    Because of the interest on ROI form this post and others, I added a section to do the ROI calculation although it doesn't include any probability of failure calculations as sc23 did. Thanks for the idea.
    Key Assumptions:
    20k pool
    1 Turnover per day (25% at higher speed, 75% at lower speed)
    120 month study period
    Existing Pump is the WFE-28 (shown as two profiles for consistency)
    2 Speed Pump is the WFDS-24 at a cost of $600
    Intellifo VS with an interface box at a cost of $1100 (enable at least a two speed timer)
    Intellifo VF with no interface at a cost of $1500 (uses internal timer for two speeds)
    The Intelliflo at high speed is set to the same flow rate as the 2 speed at high speed but the low speed setting is 1000 RPM which tends to be the most efficient.
    Scenario1 - $0.12 per kwh, the national average
    Scenario2 - $0.24 per kwh, 2x the national average
    In scenario 1 the two speed has a better NPV than the VS while in scenario 2 the VS has a better NPV but the VF is still not as good as the two speed. As you can see the outcomes are primarily dependent on energy costs, the total pump implementation costs and how the pump is going to be used.
    What was most surprising to me is that NPV spread between the different pumps was only a few hundred dollars.
    Mark
    mas985's Avatar
    Pleasanton, CA
    11,726
    The CEC has just updated their database and now include Curve C but only for Pentair pumps. So those pumps now have a bit more accuracy in the prediction of performance, including the Intelliflo. Unfortunately, they still have two pumps which seen to have erroneous data (WFDS-3 & WFDS-4).
    Mark
    Mark, You have done an excellent job bringing all this information together. You are undoubtable an experieced pool professional/Engineer and have spent a lot of time researching and developing your calculation spreadsheets. Thank you for your effort. Gary
    mas985's Avatar
    Pleasanton, CA
    11,726
    Thanks and welcome to the forum.
    Mark
    Nov 2012
    Houston, Texas
    3
    Our pool has 2 variable speed pumps (Hayward Ecostar With SVRS). One pump runs the pool & spa and the other operates a pair of fountains and a waterside.
    First, the good: i love the ability to vary the intensity of the fountains. Being able to tailor the fountain height to your mood and noise level preferences is very useful. Also, the reduced energy usage is appreciated, especially here in Houston where our pools operate all year.
    Now, the gripes:
    (1) every time I vacuum the pool manually, the SVRS trips off the pump. Frustrating. This can be overcome by manually overriding on the control unit by putting it in service mode, which upsets the pump program for several hours, creating another frustration. Another way around it is to trick the system by turning off the pump and then restarting it with the vacuum hose connected, effectively re- establishing the baseline of the suction at the higher level. This is the preferable way of handling the issue and makes the problem an almost non-issue. Still, I thought I would voice the problem in case others are facing a similar issue.
    (2) we operate our pool pump 24 hours a day at a very low RPM, except for an hour or two at a higher speed to coax any debris that is floating on the surface into the skimmer. This operating philosophy (suggested by our builder) uses very little electricity (about the same as a 100watt light bulb), provides for a constant (pleasant) trickle of water from the elevated spa into the pool and keeps the pool water well mixed. Love it. The problems with this are both related to the lower water flow produced by the lower pump speed:
    (A) the automatic chlorine feeder empties very slowly. If I were using chlorine tabs as my primary method of chlorination, this would be a problem since I would not be able to get enough chlorine into the pool water. However, since my primary method of chlorination is manually adding bleach, this doesn't bother me, except when we go on vacation and I am not here to add bleach. To address this, before we leave on vacation I load up a floating chlorine dispenser. I also alter the pump program to run at higher speeds so that it puts more chlorine into the pool from the automatic chlorinator. This puts unwanted extra CYA into the pool but gets the job done.
    (B) the heater will not turn on unless there is a minimum level of flow from the pump. Obviously, the cure for this is to run the pump at a higher speed while in spa mode. However, I am embarrassed to admit that it took me a while to figure this one out! When the system was switching to spa mode the pump would shut down to allow the valves to adjust. Upon restarting, the pumps would spin up for a couple of minutes to prime. During this period the heater would come on but as soon as the pump slowed down to normal (low) speed there was no longer enough flow and the heater would shut down. Eventually, I figured it out . One cool thing I figured out during this episode was that since the controller automatically reverts from spa mode to pool mode after a few hours, by keeping the pump speed below the minimum allowed by the heater, this limits the amount of time that the heater could be turned on accidentally before it will self correct.
    Anyway, just thought I would offer some lessons learned about variable speed pumps with the web site that has taught me so much. For what its worth, despite these issues, would use variable speed pumps again if I had it to do all over.
    Chris Pitre
    Houston, Texas
    28000 gallon gunite with plaster finish
    Elevated spa with stone creek bed between spa and pool
    Two fountains in swim out area
    Water slide
    Swim up bar with bar stools
    Baja shelf
    Chlorine pool with 2 Hayward Ecostar SVRS pumps, sand filter, 400k BTU nat gas heater, Dolphin robotic cleaner.
