Thread: Intellichlor IC40 - No Status Lights On
    Jul 2007
    Lighthouse Point, FL
    I think I'm having an issue with my chlorine generator. It's a Pentair Intellichlor IC40, and test strips (as well as the smell test) indicate that it's no longer generating chlorine.
    The LEDs on the top of the unit show that the salt level is good (green), and that the requested output level is 100%. I get NO LED indications for any of the "status" lights (Power, Cell, Life or Flow); they just sit there being dark. The unit was installed new last year, and worked without issue at a request level of 5%-7% (I've got a small pool) up until recently. We do get power outages from T-storms during the summer, and the pool system has also been shut down recently due to other work being done on the house electrical system.
    Any ideas? The manuals aren't very helpful about what the cause might be...
    22,000 rectangle pool with custom inpool steps sand filter and new autopilot swg
    Mar 2007
    Ontario, Canada
    Could it be a blown fuse in your power center? I have the IC20 but have never run into your situation. Maybe your cell is clogged?
