We have an Intex set up on grass. After the ladder is used there is a small dent / imprint where the ladder legs have been on the bottom of the pool / liner. I move the ladder around quite a bit to distribute the denting, but the pool is installed into a corner so only have about 20 degrees of the pool to move the ladder around and there is starting to be an area on the bottom of the pool which has 'sunk' where the ladder legs have been.
I am thinking of attaching something large made from flat plastic to the bottom of the legs and using cable ties so that the ladders feet don't imprint into the liner. Has anyone else experienced this issue before, and what have you used?
Thanks..
Thanks..
