Thread: Newbie on Ice.
    Newbie on Ice.
    This is my first winter with an inground pool and just about every ounce of me is skeptical that my pool will survive till Spring without some form or damage even though, to the best of my knowledge everything was winterized properly. (Eternal pessimist) It has been unusually cold here even for NC Kansas in the past month or so except for the past 5 days.
    We have been having high's in the 40's and even hit 50 yesterday! Regardless, the mild temps tempted me to lift off a corner of the cover to inspect the pool and the chlorine floater level. Much to my surprise the floater was frozen solid amid a 2" layer of ice that covers the entire top of the water surface.
    1. Should I be concerned?
    2. How long will it take this type of ice to melt with high's in the 40's and 50's?
    3. Can this ice crack my fiberglass pool?
    My water level is just even with the bottom of the skimmer flange. (the rectangular part that surrounds the opening of the skimmer.) It is not up into the skimmer yet.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    Dec 2009
    Central Massachusetts
    Re: Newbie on Ice.
    It's ok. My first year i was paranoid too. Mine is frozen solid about 6 inches down, im sure. (estimated depth by how deep the pond is frozen in back of my house). As long as the lines were blown out properly and the filter drained, relax, drink a cup of coffee and sit tight till April
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    Re: Newbie on Ice.
    You'll be ok. I'm in central ontario, where it can hit -30C often in the winter, my vinyl pool freeze solid for a couple feet down, no worries. It all thaws nicely in the spring.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Re: Newbie on Ice.
    You're square, as everyone else has said.
    When we bought the house, it had gone through 2 winters, untouched. Thawed out, and everything was fine. Yeah, it was a frozen green mess when we had the house inspected, but the ice should do no harm.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
