Thread: should i remove pump for the winter?
    Hi i live in eastern canada where winters are extreamly cold.Some ps stores around here just drain the pipes but they dont remove the pump.Other ps remove the pump and claim that the pump wont last as long if you dont.They say that there's expanshion in the empeller from freezing and unfreezing.
    What's your take on this ?
    42,000 liters inground pool
    swg aqua rite
    Hayward super filter sand
    Vinyl lining
    Haward 1.5 hp pump
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    Re: should i remove pump for the winter?
    If you drain it there's not going to be any water in the impeller to expand, so that's not an issue. If the pump is easy to disconnect then by all means do so, but in most cases the work involved to disconnect the plumbing and wiring isn't worth the small benefit. At most you'll be preventing some oxidation inside the motor.
    X-PertPool's Avatar
    Exeter, PA
    If you have unions to easily disconnect the pump and the electrical just plugs in then I would go for it and remove it for the winter. I wouldn't recommend removing and reattaching hardwired electrical to the motor since the board will probably end up breaking.
    X-Pert Pool Service
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
