Thread: Can I fix It???
    Can I fix It???
    Just had a new pool finished, I cleaned the copers down with Hydrochloric acid 1 to 5 of water.
    I neglected to wash of the excess acid from the pebblecrete & this is the result!!!
    Streaky lines down pebble finish
    Can I fix it???
    Thanks Scotty
    30,419
    Re: Can I fix It???
    Not easily. As you know, the surface is permanently etched from the acid.
    It may weather out in time and not be too noticeable...that would be my first thought. I would suggest simply leaving it alone for maybe 6 months or so and then compare it to this current picture. It may be minimized enough you can live with it.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,055
    Re: Can I fix It???
    If it really bothers you, you can put tile over it I am not sure this will help you
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Can I fix It???
    Welcome to TFP!!
    Talk to the builder, he may have another idea
    I think Dave is right about it, eventually, aging to be less noticeable. You could hasten the process by raising the water level to the bottom of the 'oops' and brush a mixture of acid onto the exposed area to even out the discolorization. This will put wear on the surface, but its an ~unused area, so no one's really gonna notice the roughness
    Again, talk to the PB and see if has a better suggestion.
    I wish you well with this, please keep us informed
    Luv& Luk
    -Ted
