Thread: Controller/Pump Problem
    My hot tub controller (Balboa VL-7000 Series according to the tub's instruction manual) has a two hour filter cycle every 12 hours. I recently cut the power to the tub to reset the time of the 12 hour cycle. It starts the cycle 6 minutes after power on.
    Since then the high/low pump that is in the low flow mode for the filter cycle stays on in low flow mode all the time.
    Normal operation has the low flow on if the tub is heating in Standard or Economy (heats only during the filter cycle) mode or during the two hour filter cycle in Sleep mode.
    If turned on at other times it may run in low flow for a minute before shutting off.
    I have cut the power for several hours hoping it would boot up and cure the problem, but no luck.
    Any thoughts or suggestions?
    Curmudgeon
    350 gal Infinity using BBB
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Controller/Pump Problem
    You can run 2, 5 or 12 hour filter cycles. You may have reset it to 12 hour. Try pressing "Temp Up/Warm" and then "Jets" to see if that changes the setting.
    Bingo.
    Thanks spishex, that was the problem.
    A few days ago I had been showing a friend how to turn the pumps on and off so he could use the tub if we weren't home. He was pushing buttons and had changed the filter cycle to 8 hours (2, 4, 6, 8, & continuous are the options on my controller).
    I very much appreciate your suggestion.
    And this is why I have been suggesting this most useful forum to my friends and to on the Yahoo Hot Tub group.
    Thanks
    Curmudgeon
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    No problem! Glad it was just a programming thing.
