Thread: freezing ag pool
    Sep 2009
    Alabama
    22
    freezing ag pool
    Hey,
    You guys were so helpful in converting our pool to the bbb method thought you might have suggestions now. We live in Alabama (Roll Tide Roll!) and normally have mild winters. However, this year we've had sustained below freezing temps in the 20's and below for about a week and it's expected to be below freezing for the next 3 days. Our pool has a frozen layer over the top because the skimmer door froze overnight and interrupted the water flow. It's flowing again now and the top layer of ice has thinned to about 1/8th inch. We have a shed over the pump and have enclosed 3 sided with plastic and a flood light shining on the pump, so that seems to help. Any suggestions ??
    Thanks so much!
    Debbie
    13,500 gal AG, cartridge filter, 2 sp Waterway pump. TF-100 Test Kit (Love it !!) Repeating Pool School.....learn something new everyday !
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: freezing ag pool
    Advice from us northerners who winterize won't help you. Maybe someone midway up the country who deals with occasional freezes will have other suggestions for you! Good luck hope it works out ok
    22,553
    Run your pump 24/7 until the temps rise above freezing most of the day. If you have a 2-speed pump, run it on high. Aim you return eyeball(s) so that they disturb the surface of the water. That will keep the surface from forming ice and also help keep the water at the skimmer opening disturbed. Keep your water level about midway to the lower 1/3rd the skimmer so that the skimmer door is pulled down during circulation. This will help keep it from freezing closed. The enclosed equipment is a good idea.
    Sep 2009
    Alabama
    22
    Thanks for the feedback, we've monitored all day, removed as much ice as possible and added water to get level back up. Still a large floating sheet of ice in the center but the sides are clear and water is moving. Temps down to 18 overnight, so we'll continue to monitor to make sure it doesn't freeze up. The skimmer door broke, when it froze in the upright position overnight, but it appears to be ok without it for now.
