Thread: cloudy pool
    Jun 2007
    New Jersey
    33
    cloudy pool
    Went on vacation for 2 weeks, turned off filter, although I have a timer on my pool (I didn't have anyone to come over to clean skimmer). Came back to green pool, I shocked to 15 since my cya is 30, after 4 days, pool was back to blue to but cloudy. I can see low end but the deep end is cloudy. I have been running my filter for 24 hours 7 days now. Here are my numbers:
    fc = 20
    ta = 120
    ch 120
    cya = 30
    ph 7.2
    Should I increase the ch - I haven't touched that since I have a vinyl pool and when I tested no calcium was present.
    20x40 rectangle inground vinyl pool
    33K gallon of water
    1 HP Hayward Super pump
    Hayward high capacity sand filter S245T -250 pound sand
    pool is over 20 years old
    1 return line
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Brush and vacuum all you can to keep the stuff where the filter can get it. Otherwise you are on the right track.
    Also, if you haven't backwashed/cleaned the filter in the last week now would be a good time to do so.
    Jun 2007
    New Jersey
    33
    Yes, I've vacuumed, backwashed, and cleaned the filter.
    33K gallon of water
    1 return line
    Jun 2007
    North Florida
    79
    Re: cloudy pool
    Quote Originally Posted by poolhelp
    ch 120
    If your calcium is 120 in your vinyl pool, no you don't need to increase it. I guess I don't understand when you found there was "...no calcium present."
    Sandy
    15,600 gallon, screened 15 x 30 sport pool with 6 x 8 baja shelf, IG plaster (Diamondbrite??), Hayward cartridge filter, 1-HP Hayward pump, Hayward/EUS Mark VI heat pump, Polaris 280, AquaRite SWCG
