Thread: Pool calculator and raising TA
    Vero Beach, FL
    462
    So my TA is at 40 and I wanted to raise it to 60 so that my CSI is in range. I added the amount of baking soda per the pool calculator, but it says it is going to raise my pH too - but it does not say by how much. Is there a reason it can not be calculated? It would be nice to be able to add the baking soda and the muratic acid at the same time.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Pool calculator and raising TA
    It's a difficult calculation, as are all pH calculations, but basically the pH doesn't change much. Assuming you don't have borates in the water, then the expected pH change is something on the order of going from 7.5 to 7.6, so a small rise. In practice, you may have a larger rise if you add the baking soda too quickly in one place with surface aeration which will cause a lot of carbon dioxide to outgas. To minimize this, add the baking soda slowly and have any return pointed out or downward (not upward) to minimize surface disturbance. Alternatively, you can mix the baking soda in a bucket of pool water and slowly pour it around the pool.
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by se_bb2
    buy alkalinity raiser at your local pool store, and add about 2 pounds. that will only raise your alk not your ph. much easier and faster.
    Alkalinity raiser from the pool store IS baking soda. Same thing. Sodium bicarbonate.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    And it will still raise your PH, though not by very much.
    Mar 2007
    San Rafael, CA USA
    12,082
    Baking soda (or Alkalinity Up from a pool store) is not less concentrated. It is a different chemical than found in pH Up products.
    You don't use baking soda to raise the pH. Jason is just saying that it can raise the pH a little as a side effect to the primary usage which is to increase the Total Alkalinity (TA). In other words, to raise the TA, use Arm & Hammer Baking Soda (same as Alkalinity Up from a pool store). To raise the pH with no change in TA, aerate the water. To raise the pH with some change in TA, use 20 Mule Team Borax. To raise both the pH and the TA (if both are very low, for example), use Arm & Hammer Super Washing Soda (same as pH Up from a pool store).
