Results 1 to 10 of 10
Thread: diy winter cover
    Jan 2010
    Claremont california
    100
    diy winter cover
    Hello friends,
    Have any of you used heavy duty tarp material as winter covers?
    I am trying to keep all of tree leafs and pine debris from going in to the pool. Safety covers are great but they are out of my budget. I also looked in to winter covers but I do not like all of the water bags that hold it in place. I decided to look at this 5oz fabric and perhaps cut it to so that it can get somewhat of a custom size.
    http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... K:MEWAX:IT
    I am planning in holding the cover in place with some kind of anchoring system, similar to those in the safety covers. I want to keep the budget under two hundred dollars.
    Please advice,
    George
    22k plaster pool kidney shape. Pentair 4000 de series 48 ft. 2 SKIMMERS, 2 drains (pool and spa), 3 returns (2 pool and 1 spa) gas heater and pentair intelliflow , Underwater pentair light.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: diy winter cover
    Are you planning a cover that floats on the pool or one that remains above the water like a safety cover?
    The tension on a safety cover is pretty high, since the force on the cover can be very high with snow or ice (or a baby elephant )
    If you try to hold it taut, a tarp like you are considering would hold water and put an enourmous load on the support system. I don't believe the fabric would hold. Safety covers have nylon straps sewn in to handle the stresses from the anchor points.
    If you try to float it on the water, you'd require a pump to empty the cover regularly, and I don't see any benefit over a standard cover. All of the leaves and debris would be in the tarp, with no easy way to get it out in the spring.
    I installed my safety cover myself for a total cost of $1200. Worth every dime.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Hey John...curious...where did you get your safety cover?? I'm going to break down and close the pool next year since the winters here seem to be getting colder every year. I want a safety cover with at least a mesh center or maybe even all mesh so the water can seep through and I won't need a sump pump. $1200 sounds a lot better than the $2400 I was looking at a couple of years ago!
    BTW...nice taste in avatars!!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    Jan 2010
    100
    Quote Originally Posted by JohnT
    Thanks for your advice and I see your point!
    I live in S. Cal my problem will be only water on top of the cover. I was thinking in making the cover like a safety cover with anchors. To solve the water weight problem, I was going to make sure to have some king of drainining system like the safety covers have. For the leaf I would clean blow clean as needed.
    Can you please let me know where you purchase you safety cover?
    Please advice,
    George
    Mar 2007
    Coastalish 'down easter'
    4,160
    George, welcome to TFP!!
    The cover I saw on your link was the same as a cover we use with the waterbags. As I believe was said, if you go that way, you'll need to police the amount of water on the cover!
    If you don't want to use the waterbags to hold it in place, you can tie it (via the grommets) to the fence or other things around the pool - cinderblocks or other sharp, heavy items could cause damage to the pool if (and possibly, when) the cover gets pulled into the pool
    A true safety cover would be optimal for you, but if the $$ just isn't there, so be it
    Karen, I'll agree that John stole your avatar (it took me a small while to realize that his posts weren't yours :P ) We can all share avatars, look at how many folks use mine
    BTW - I love the avatar
    Luv& Luk
    -Ted
    SW Indiana
    9,199
    I got my Loop-Loc from poolcenter.com
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Karen, I'll agree that John stole your avatar (it took me a small while to realize that his posts weren't yours ) We can all share avatars, look at how many folks use mine
    Oh, I wasn't trying to accuse him of stealing it! I'm glad to share the mentality.. I really was complimenting him on his good taste!
    So, John...how easy/difficult was it to install??
    TIA
    Karen
    10,700 gal IG vinyl
    2 skimmers
    SW Indiana
    9,199
    Quote Originally Posted by midtngal
    TIA
    Karen
    It wasn't hard. It requires a hammer drill and 3/4" bit. Drilling the holes is fairly jarring, so I didn't do them all in one night. I strung ropes across the pool to hold the cover until I had enough anchors in to hold its weight. That let me see where the straps were to figure out where to put the holes.
    Jan 2010
    100
    Hello friends,
    I was able to do a little research regarding the materials that I might use for my winter cover project.
    Bungee http://cgi.ebay.com/25-Feet-3-8-Black-S ... 56387d57b3
    Hooks http://cgi.ebay.com/3-8-Bungee-Shock-Co ... 4a92961903
    Anchors http://www.fastenal.com/web/products/de ... 403&ucst=t
    Eye hooks http://www.boltdepot.com/product.aspx?c ... m=7&cd=280
    Tarp http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... K:MEWAX:IT
    I might just do a little smaller diameter bolts and anchors.
    Please let me know what you guys think?
    George
    Dec 2009
    Central Massachusetts
    2,690
    My honest opinion? I dont think this will work too well. Too much tension on the cover, even if its just rain water. Loop loc type covers are made for the weight. The anchors are made for the application. I think this will be nothing but trouble. Stick with the tarp and water bags for your cover. Save your bucks and get a proper Loop Loc. Just my 2 cents.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
