Thread: Trouble with Paramount 6 valve module
    Sep 2009
    Tucson AZ
    120
    Built new pool 5 years ago and had Paramount 6 valve in-floor cleaning system installed. Worked great until about a year ago, when I noticed that it was not cycling from one zone to the next; instead one zone of nozzles was stuck up. I took the cover off the valve module and cleaned the inside with fresh water. Worked fine until about a month ago, when a zone was stuck up again. Fixed it the same way, but now it's stuck again. Should I replace the whole valve module or is there a better way to unstick those valves so that it cycles through the zones.
    16,000 gal in-ground Pebble-tec pool / Pebble-sheen spa. Jandy AquaPure 1400 SW Cl gen (SWG) system. In-floor cleaning system w/ Hayward EcoStar 2.0 HP VSP pump. Hayward 31" sand filter. 900 sq ft Heliocol solar panels (on roof) w/ separate 1 HP Pentair WhisperFlow single speed pump. Water feature with separate Hayward 0.85 HP VSP pump.
    South Central NJ
    3,192
    Re: Trouble with Paramount 6 valve module
    When that happened, it's time to replace. Not cheap.
    Scott
    Owner of - PoolGuyNJ LLC
    Sep 2009
    Tucson AZ
    120
    I was afraid of that. About $200 for a new one. Thanks for getting back to me.
