Results 1 to 14 of 14
Thread: Question about my pump, feedback needed.
    Sep 2009
    Spring, TX
    258
    As any of you may have read I just got back from a two week vacation. I came home and went to check the pool and I could not even get the skimmer basket out. It was full of leaves. I had to pull leaves and more leaves out and finally got the basket out. I did not see any leaves below the basket. I turned off the pump and went to check the small basket by the pump and it was about 3/4 of the way full. It is weird that this happened due to the water being higher than normal. I emptied both baskets out and put it all back together. I turned on the pump again for about 5 minutes and turn it off. The small basket by the pump was about half full of leaves. I did the same thing again and the small basket had about 1/4 full. Then the last time just a few leaves. Am I safe to assume that my pump is ok. The pressure is a little above 10 and seems to still be sucking pretty hard. The return jets are still going strong. So do I need to worry about anything or am I just fine?
    Thanks.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Question about my pump, feedback needed.
    Sounds like all's well
    The question is how the leaves bypassed the skimmer basket (BTW- next time you go to empty the skimmer basket, and it's full, turn off the pump first so that you can more easily remove and empty the basket
    Please let us know if you have further issues with this.
    Luv& Luk
    -Ted
    Sep 2009
    Spring, TX
    258
    Quote Originally Posted by waste
    Yea not sure how they got passed it as I see no holes in the basket. The only thing I can think is they either got by on the side or through the small small holes at the bottom of the basket. Or maybe the water pushed the basket up slightly and they got in that way.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by laurandavid09
    I used to wonder about that, too. Here's what happens in my pool: The skimmer basket fills up with leaves via suction during pump operation, but when the pump turns off the skimmer basket floats up out of the well and some of the leaves come to the surface or even float back out into the pool. When the pump restarts, normally the basket reseats, the leaves that had fallen out are sucked back in, etc. until I empty the basket. Once in while, however, the basket has risen too far and the suction created when the pump restarts pulls in the leaves ahead of the basket (leaves don't weigh as much.) On several trips I've returned to find the skimmer basket upended with leaves wedged around the sides and layered on top. Only once has this been so severe that the pump filter basket became so clogged with debris that it couldn't prime.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    mas985's Avatar
    Pleasanton, CA
    11,741
    With my skimmer, the basket will lock into the skimmer with a slight turn after it is seated so it won't float up when the pump is shut off. You might check to see if yours has that feature as well.
    Mark
    May 2009
    Dallas, TX
    785
    I had to put a rock in my basket to keep it from floating. Not very elegant, but it works...
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Jan 2009
    Cupertino, CA
    1,966
    Mine came with a weight to keep it from floating.
    On the other hand.... we were visiting my SIL last week and their pool has a skimmer that looks like the basket was intended to float. No weir flap, basket is narrower and deeper than I'd expect, with the pump on it's floating about 1/2" under the surface and there is really major skimming action. (I looked at it because I notice the returns were blowing air; the skimmer was plugged with leaves and sucking air. After cleaning it out I spent a few minutes trying to figure out how to make the basket stay down, and there just wasn't any way I could find. But it seemed to work when floating.)
    --paulr
    BBB "Intermediate Swimmer"
    30,431
    I'm with Beez, the rock works for me.
    I even picked up a couple of smooth, quartz-like ones that get all cleaned up in the skimmer and fun to admire when I dump. (it doesn't take much to entertain me)
    22,553
    Mine is like Marks, it has lips that the basket flange locks under with a quarter turn of the basket. Even with that once the basket is completely full there's a small space around the basket that a leaf or two can get by and make it to the pump strainer.
    laurandavid -- I agree with the other posters, if you've cleaned out the baskets and the suction and discharge seem normal, everything should be good. You probably want to check the impeller for obstructions but you don't need to be in any hurry to do it.
    South Central NJ
    3,192
    Careful putting rocks in. They have a habit of falling out. Murphy's laws dictates it will go down the skimmer line and get stuck.
    Scott
    Owner of - PoolGuyNJ LLC
    May 2009
    Dallas, TX
    785
    Quote Originally Posted by PoolGuyNJ
    Scott
    That's why you make sure that the rock is bigger than the hole in the skimmer!
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    There's been more leaves in my pump basket than I expected since I recently had cleaned it out. After wondering how the leaves were getting in there, I finally figured it out! I have a suction side cleaner(Navigator) which just sends whatever it picks up directly to the pump basket. I guess I'll have to clean out the pump basket more often than I thought.
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
    mas985's Avatar
    Pleasanton, CA
    11,741
    I use a leaf trap such as these. It keeps the leaves out of the pump basket.
    Mark
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    Thanks for the link! I've heard of those, but thought I wouldn't need it with no trees in the yard. But I definitely could use one.
