Thread: recs for energy efficient pumps
    Aug 2009
    SF Bay Area (Lamorinda), CA
    122
    Hi
    we're considering replacing our pool pump if the possible energy savings would make it worthwhile. Our current setup is:
    17K gallon rectangular in-ground concrete pool that was resurfaced with fiberglass by a previous owner. One skimmer and one return, functioning status of main drain unknown.
    Hayward S244S Sand Filter with Franklin Electric 0.75 HP motor and WhisperFlo WFE-3 pump
    1950's-era 17K gallon formerly fiberglass, newly replastered IG rectangle (~15x30'),
    Clear ThermaTex bubble cover
    Manual vacuum
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: recs for energy efficient pumps
    Quote Originally Posted by PoolCleanerMom
    Hi
    Well, I know some of the right questions to ask....
    WhisperFlo #11512 WFE-3 115/208-230V 11.2/6.0/5.6 Amps 3/4 HP 1.67 SF << Does this describe your current pump?
    If correct, it can be used to compare specs with other pumps. Here is the performance curve diagram for the WFE-3 pump (reference the 'F' curve)
    What size pipe diameter for skimmer and return lines (1.5" 2")?
    Does the main drain have a separate PVC run back to the pad or is it connected to skimmer?
    Why do you suspect it's not functioning?
    What's the pressure reading (PSI) at your sand filter when it's clean?
    Do you know current flow GPM?
    Do you have solar panels? Heater? Spa? Waterfall?
    What type of cleaner? (suction side or vacuum? pressure side? booster pump for cleaner?)
    Do you want to consider a two-speed or variable speed pump (less expensive to operate but higher initial cost)? A new pump will cost $500-1600, excluding labor; the return on your investment will depend on your pool configuration, the relative efficiency of the pump replacement and any energy rebate or tax credit that applies.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    mas985's Avatar
    Pleasanton, CA
    11,741
    The WFE-3 is pretty efficient to start with but a 2 speed or variable speed pump would be better. It depends on how much money you have to spend and how short the payback period you are looking for. Several options:
    1) Replace existing motor on pump with a 2 speed: Equipment Cost: ~$300, Energy Savings ~%50 on low speed
    2) Replace entire pump with a 2 speed: Equipment Cost: ~$500, Energy Savings ~%50 on low speed
    3) Replace entire pump with a variable speed: Equipment Cost: ~$1000, Energy Savings ~%60-%80 (depending on speed settings)
    The true cost savings tends to be a bit less than I showed because the pump is not always run at the lowest speed. This is especially true with a variable speed since the highest cost saving settings have the lowest flow rates so the skimmers and cleaners won't work as well which means you may have to run at higher speeds at least part of the day for effective cleaning.
    Being in a high electric rate region as you are, the variable speeds tend to pay for themselves in only a few years and the 2 speeds in less than a year. But over the life of the pump, the variable speed will save you the most money overall.
    Mark
    Jan 2009
    Cupertino, CA
    1,966
    I have similar specs and an unhappy electric bill, thinking about replacing mine too. I will note that PG&E no longer offers rebates on 2-speed but still does on variable-speed.
    http://pge.com/myhome/saveenergymone...nal/poolpumps/
    --paulr
    A discussion of one specific brand of pump, that was getting off topic, has been moved to here. JasonLion
    BBB "Intermediate Swimmer"
    Jul 2007
    North Texas
    55
    My intelliflo vs pump has been in service for 30 months, maintaining a 26k IG pool. I estimate the pump and swg uses between 2-8 kwh/day depending on the season, how dirty the filter is, and how much I run the cleaner and water feature. I run it year round turning over between 12k and 21k gpd.
