Thread: Baracuda G3 - will it hurt pool pump?
    New house, first pool:
    The pool guy told us to turn off the main drain and only use the Baracuda G3 Vacuum (Which runs off the main pool pump) with skimmer on partially 100% of the time. I'm worried this might put a constant high load on the pump and shorten it's life. Any input or experience with this?
    Thank You
    18k gallon, plaster, Hayward DE6020 filter, 2.0 HP Hayward pump, H Series Hayward heater, inline chlorinator (that I no longer use as I have switched to BBB)
    Feb 2008
    Flower Mound, TX
    Re: Baracuda G3 - will it hurt pool pump?
    I don't think so. That's how I have run mine for ages. Skimmers and Baracuda 100% of the time with the main drain completely closed. The only time that I run the main drain is if I am draining lots of water or if we are expecting a freeze and I want water flowing through all of the pipes.
    10K gallon IG gunite with waterfall; Pentair CC320P filter; WhisperFlo 2 HP pump
    TF Test Kits - Pool Math - Pool School
    "It depends."- JohnT
    South Central NJ
    This depends on the pump and plumbing size. Larger pumps, 1-1/2 HP and up may have more suction than it needs. If this is the case, cracking open a second suction source is suggested.
    This type of suction side cleaner is not noted for their speed. If it can still climb walls successfully with a second suction port open or cracked, it is better for the equipment and lines, especially if the suction lines were laid using flex pipe.
    There should be a spring loaded regulator that is supposed to relieve excess suction. Usually they work but not always.
    Owner of - PoolGuyNJ LLC
