Results 1 to 9 of 9
Thread: Major leakonthe clamp ring of my booster pump
    rogerbrks's Avatar
    Round Rock, TX
    172
    Booster pump started leaking at the clamp. I applied a multi purpose lubricant-sealant with PTFE. This minimized the leaking but not completely. any recommendation or advice is highly appreciated. We're going below freezing tonight and I really need to get this solved.
    21,200 gal IG gunite, CL 580 sqft Cartridge filter, aqua pure salt system, polaris 480-blue&white, Jandy PDA Remote, (4) Jandy Deck Jets
    South Central NJ
    3,192
    Re: Major leakonthe clamp ring of my booster pump
    Post a picture.
    Scott
    Owner of - PoolGuyNJ LLC
    rogerbrks's Avatar
    Round Rock, TX
    172
    I am just now able to reply with a picture because it has taken this long to get the part from Poolcenter.com. It's amazing at how I've ordered other items after this one and they came several days before. I am very unhappy with delivery time from Poolcenter.com. I order a new o-ring to try to stop the leak around the clap band. To no avail though. I'm not sure what else to do.
    South Central NJ
    3,192
    If the o-ring didn't do it, the flange on the front section of the wet end is cracked and needs replacing. If it's not available, then put a Polaris booster pump in it's place and replumb as needed.
    Scott
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Definitely looks cracked to me. Do you have a shut off valve for that line? If so I'd shut it off and take off the band to let the pump and plumbing drain out.
    rogerbrks's Avatar
    Round Rock, TX
    172
    Excuse my ignorance of what a flange is. Are talking about the metal band clamp?
    22,553
    I agree with spishex. The housing looks cracked to me. You need to pull the pump apart and take a good look at the housing near the flange. You may be able to buy a replacement part.
    South Central NJ
    3,192
    The flange is the outer part of the housing the clamp holds.
    Scott
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    I'm sure you have fixed this by now, but the terminology your looking for is a volute, for a Polaris QT pump. It's the latest generation from Polaris, so it's available.
    Factory Warranty Station for:
